starting problems (2005 smart) - Page 2 - Smart Car Forums
 1Likes
post #11 of 16 (permalink) Old 08-25-2010, 12:30 PM
starting problems
Hi,
I have a 2005 450 and last month the car starter motor did not crank the engine. There are many potential causes.
If the starter system was working properly and the shifting system was working properly prior to the no crank problem...theb this could be the problem.
With mine, appearantly G+K did some rewiring of the speedometer. I noticed that along with the no crank problem the 3 bars were flashing in the transmission display on the speedometer and other times the transmission indicator was blank, no flashing key symbol.
IT"S A LOOSE WIRE TO THE SPEEDOMETER. I banged on the on the speedometer and one of the illumination lights flickered and then came fully on. At the same time the key symbol started to flash and I knew i had found the problem. The car statrted normally, except the 3 flashing bars needed to be reset by a battery disconnect. The speedmeter has it's own computer which talks to the main computer and is telling it that something is wrong (from the loose connection) and the main computer responds by not starting the car.
I removed the speedo and "exercised" the wires and connectors to "improve" the bad connection. I have had no problem starting for the last month.
Many suggestions were proposed as to what was wrong, from dead battery, bad grounds, bad starter motor, bad transmission motor. Non of these were the problem.
One suggestion that should also be checked is the brake switch, as it is prone to failure and would result in a no crank condition. Any questions call 845 298 4229.
bshul is offline
post #12 of 16 (permalink) Old 09-07-2010, 06:01 AM
briansmart's Avatar
Quoted: 1 Post(s)
Thanks for the tip bshul.
If I have read correctly, no start in a 450 should have the following trouble shooting performed:
  • check battery
  • check starter relay in SAM
  • check for loose connection(s) in speedometer housing
  • check for broken brake switch
The brake switch is so common that there is a test written up at Evilution: Evilution - Smart Car Encyclopaedia
And the brake switch replacement how-to:
briansmart is offline
post #13 of 16 (permalink) Old 10-07-2010, 09:28 AM
My 2005 Smart left me stranded out of town yesterday. I had made several stops on my way to my destination. At my last stop my car engine would not make a sound, not even an "I'm trying".
A good samaritan tried jumping the car. No luck! 2 other good samaritans tried to roll start it, no luck.
I'm going back to retrieve the car tomorrow, Friday. Does anyone have any suggestions? The battery is new and has plenty of "juice".
Also, yesterday my key fob would not lock or unlock the doors. Could that be part of the problem?
lazy river is offline
post #14 of 16 (permalink) Old 10-07-2010, 09:45 AM
Lazy River 2005 No Start
Hi,
My 2005 Smart requires a door unlock from the key fob before it will be allowed to crank. The key fob need to work. Do you have a spare fob?
Is there a flashing key symbol in the speedo gear shift display when the key is in the ON position?
Call me 845 298 4229....Burt
bshul is offline
post #15 of 16 (permalink) Old 06-12-2017, 10:49 AM
Hey Everyone,
I have a smart for 4 and removed the battery and replaced it with anew one. After connecting the new battery, a key symbol appeared on the dashboard and the car would not start. The engine turns and everything works but the engine just won't pick to keep the motor running. help please.
deedee is offline
post #16 of 16 (permalink) Old 06-12-2017, 02:02 PM
Bohemian Moderator 451gas
Quoted: 78 Post(s)
Welcome to SCoA! Since your car is basically a Mitsubishi Colt you might try a Mitsubishi dealer or mechanic if there's one close.
Huronlad likes this.
jwight is offline
Local girl starting Smart Madness SmartGurl Smart Owners Club of San Francisco 0 05-18-2009 07:31 AM
SCG Navigation blow out starting @ $1,250 Seanpz1 Mid-Atlantic Region 0 02-11-2009 06:52 AM
Starting them young JoeyCrack The Car Lounge 0 06-04-2008 05:27 PM
Not starting (ignition) issue kmeinhold smart Operation and Maintenance 5 02-14-2008 11:11 AM
