Unlocking key also unlocks rear window, causing interior light to stay on. - Smart Car Forums
post #1 of 10 (permalink) Old 03-15-2012, 07:59 AM Thread Starter
Is there a solution for this? I don't think it was doing it at first, I just got my car on Friday. For now I'm going to unlock the key before getting in the car, then shut the rear window BEFORE getting in the car so I don't have to get out of the car to do so.
Any advise?
JanRN is offline
post #2 of 10 (permalink) Old 03-15-2012, 08:38 AM
Huronlad's Avatar
Quoted: 329 Post(s)
When you press and hold the hatch unlock button on the fob, does it do anything?
Huronlad is offline
post #3 of 10 (permalink) Old 03-15-2012, 08:54 AM Thread Starter
Not sure what fob is or where hatch unlock button is. Just got car a few days ago
JanRN is offline
post #4 of 10 (permalink) Old 03-15-2012, 08:58 AM
Huronlad's Avatar
Quoted: 329 Post(s)
Are there three buttons on the key for your car?
Huronlad is offline
post #5 of 10 (permalink) Old 03-15-2012, 09:04 AM Thread Starter
Yes, I have to unlock the key to start the car, when I press that key unlock button the rear window also unlocks, that's my problem
JanRN is offline
post #6 of 10 (permalink) Old 03-15-2012, 02:27 PM
Quoted: 2 Post(s)
Any advise?[/QUOTE]
What year is your car? how many buttons on the Key?
smart2 is offline
post #7 of 10 (permalink) Old 03-15-2012, 02:45 PM Thread Starter
2005. 3 buttons on the key.
JanRN is offline
post #8 of 10 (permalink) Old 03-15-2012, 06:53 PM
HGB
HGB's Avatar
Quoted: 33 Post(s)
When the left key is pressed the driver's door is unlocked and when it is pressed a second time the passenger's door is unlocked. This also makes it possible to unlock the rear hatch manually by inserting your fingers under the glass lid and pressing a switch upwards. A small click is then heard which confirms that the glass can be lifted.
The right button when pressed for about a second or more will activate a solenoid which releases the latch and the rear glass will actually pop up a little. Just lift the glass window a bit and it will go up for quick access.This is great when your hands are full of groceries for example. The remaining center button will lock your car-- providing both doors and glass lid are clicked shut. This locking is confirmed with 3 light flashes.
As for an interior light staying on, check whether the light switch between the two visors is in the proper position for automatic operation.
On my car it's the part which is closest to the driver which is depressed.
There are various timers built into the car which will turn off the light after a while. Let's say you get into the car and sit inside, the moment the engine is started the light will go out. Good feature.
The last button which is practically never used is the red button. Let's say you approach your car with packages in your hand and some unsavory characters are nearby lurking about. Then just press the red button and the horn will begin blowing on and off. This a simple way of creating attention and hopefully will discourage any bad guys from doing you harm. I hope you you get this and I hope I understood your question correctly.
HGB is offline
post #9 of 10 (permalink) Old 03-17-2012, 07:24 AM
Leroy's Avatar
Quoted: 4 Post(s)
Leroy
Leroy is offline
post #10 of 10 (permalink) Old 08-22-2018, 09:14 AM
Quoted: 56 Post(s)
If your fob has the third button to open the hatch only it has to be held for quite a while. As I walked toward the Smart it is way over the normal 3 second activating time. Roughly plus five seconds. Since I leased it in February, I thought it was a quirk that it would never work. I guess I didn’t have the patience to wait. One day I did. I really can’t see a huge use for it. On the electric, one hit opens the driver's door, second, the passenger, third, the hatch and fourth the ED port. I am probably wrong and the third also opens the ED flap.
halfcack is offline
Battle between key fob and interior unlock/lock (doors not closed) 3sixjoshua smart fortwo (451 - US vehicle) 12 02-18-2012 09:53 AM
Dome light doesn't stay on when car is locked tigerwong58 smart Operation and Maintenance 1 11-25-2010 03:08 PM
red interior light sspikey Interior & Exterior 4 05-03-2010 10:18 AM
Interior dome light replacement ETCMJF Interior & Exterior 2 05-11-2008 02:03 PM
