2008 Smart Fortwo running rough!! - Smart Car Forums
 5Likes
post #1 of 23 (permalink) Old 07-15-2017, 08:04 PM Thread Starter
Munster's Avatar
Quoted: 14 Post(s)
Hi, The engine light in my Smart is on, I know I can put it on a scanner to find out why but until then maybe someone can help me. The car runs fine but when I stop at a stop light the light starts flashing and when I take off it's all herky jerky and sputtering and has no power. If I stop and turn the car off and re start it it runs fine. Any ideas of what it could be. I don't know if it is maybe a bad O2 sensor or what. Any suggestions would be appreciated. Thanks Munster
Munster is offline
post #2 of 23 (permalink) Old 07-15-2017, 08:16 PM
Quoted: 768 Post(s)
doesn't sound good... My guess is you are losing a cylinder. Hopefully it is a bad plug or coil. You are most likely going to see a P0300, P0301, p0302, or P0303. depending on the miles, I would change plugs, and maybe look into a compression test.
If the engine detects a cylinder loss, it will shut down that cylinder to try to save it. shutting off the car and restarting it will reset that but if the problem isn't fixed, it will happen again.
If you get a FLASHING Check Engine Light, that is usually a bad thing and you shouldn't drive it unless you find out what is wrong.
jimvw57 is offline
Soundeng (02-25-2019)
post #3 of 23 (permalink) Old 07-15-2017, 08:19 PM Thread Starter
Munster's Avatar
Quoted: 14 Post(s)
The car has 92,000 miles on it.If I was losing a cylinder why would it run good again after I restart it? I only got half of your reply until after I replied back.Thanks for the info.
Munster is offline
post #4 of 23 (permalink) Old 07-16-2017, 11:16 AM
Rustedwrench's Avatar
Quoted: 224 Post(s)
If the ECM detects a misfire it can turn off the fuel injector for the offending cylinder so it is not dumping unburned fuel out the exhaust. The injector is re-enabled when the key is turned off, then on again.
Rustedwrench is offline
The Following 3 Users Say Thank You to Rustedwrench For This Useful Post:
Miss Mercedes (02-25-2019), Mister_smart_LA (07-30-2017), Smart Bob (07-16-2017)
post #5 of 23 (permalink) Old 07-23-2017, 05:34 PM
Yukoner's Avatar
Any funny smells ? My mind goes to plugged cat converter as a possibility. Mind you, there should be no reason why it would run fine after restarting, unless you let it sit for a while.
Yukoner is offline
post #6 of 23 (permalink) Old 07-23-2017, 06:22 PM
Quoted: 768 Post(s)
My 2009 ran good for 168,000 miles until one day it dropped a cylinder when heading to work. I drove about 3 miles and it would shudder and shake, no power, etc. When I shut it off and restarted it, the CEL went off and it ran for another 3 miles or so. eventually the CEL wouldn't g out but I could reset it with my scangauge II. I got a compression tester and found cylinder #1 had 65 PSI and the others had 155 and 160. even after finding that, it would run OK for a bit before the computer would shut down the cylinder. Exhaust was replaced at just over 100K miles.
Car was driven roughly 100 miles a day on highways and back roads so it didn't have any carbon built up. Adding oil to the cylinder did not change the reading so I assume it was a burned valve. Regular oil changes with Mobil1, premium gas and filter changes at recommended intervals, same with plugs, etc.
The computers on these cars do a big job of monitoring a massive amount of sensors, they will detect a problem before you can feel it.
jimvw57 is offline
post #7 of 23 (permalink) Old 07-27-2017, 07:18 PM
Yukoner's Avatar
168K miles, nice ! I was wondering about lifetime mileage expectancy.........
Yukoner is offline
post #8 of 23 (permalink) Old 07-30-2017, 02:42 PM Thread Starter
Munster's Avatar
Quoted: 14 Post(s)
How are the cylinders numbered?
Munster is offline
post #9 of 23 (permalink) Old 07-30-2017, 02:53 PM
Smart Bob's Avatar
Quoted: 173 Post(s)
They are numbered right to left with the right side being cyl. #1.
Smart Bob is offline
The Following User Says Thank You to Smart Bob For This Useful Post:
Munster (07-30-2017)
post #10 of 23 (permalink) Old 02-25-2019, 11:04 AM
Thanks for the info....
Hey guys - I have a 2008 Passion doing these exact things - just started this morning....
Check engine light popped on and the car runs rough - I got it home thank god - but this thread at least gave me a direction to start looking.... Gonna have the code read so I know exactly....it only has 67000 miles on it...
I've been working on cars for years - but this is my first Smart - and I love it as my commuter car..
I was gonna buy spark plugs soon anyway cause they are due - but I'm hoping the code will give me there exact issue...
Soundeng is offline
For Sale: 2006 fortwo passion coupe not running hoov23 smart Vehicle Marketplace 2 11-11-2017 07:26 AM
Rough Idle and Running mbiskie smart Operation and Maintenance 12 01-25-2016 12:44 PM
2008 Smart Fortwo FOR SALE. NOT RUNNING xavif310 California Chapter 4 08-09-2015 11:00 AM
2008 Smart Fortwo Gasoline Engine + Transmission (Running Condition) SmartRT smart Parts Marketplace 0 08-01-2013 08:26 PM
Smart : Fortwo Passion Heated Seats 2008 Smart Car Fortwo LOADED Great price MINT! Smart Cars For Sale Archive/obsolete (?) threads 1 01-31-2009 03:17 PM
