2008 Smart Fortwo running rough!! - Page 2 - Smart Car Forums
 5Likes
post #11 of 23 (permalink) Old 02-25-2019, 12:16 PM
Mod ♥ 450/451/453 + Motos
Miss Mercedes's Avatar
Quoted: 164 Post(s)
You'll likely get a code for a cylinder misfire, which outside which cylinder is the offender (the code will likely be P030x, where "x" = the cylinder that's missing, so 1, 2, or 3), it won't tell you much.
I think you already have a good plan starting out with new plugs. At one time following a small engine fire I had a misfire on two cylinders. It was thought my engine was cooked, but I tried to revive it anyway. The plugs kept getting covered in oil and I was lucky to get two cylinders running on any given day. I went for plugs in a slightly higher heat range and ran some Marvel Mystery Oil. A couple spark plug changes later (they kept getting oil fouled) it eventually just stopped happening and the engine is healthy today.
Welcome to SCoA!!!
Miss Mercedes is offline
The Following User Says Thank You to Miss Mercedes For This Useful Post:
Soundeng (02-25-2019)
post #12 of 23 (permalink) Old 02-25-2019, 03:35 PM
Awesome!!! Thanks for the info and the welcome......
Ill def take your advice on the mystery oil - I have yet to do an oil change on the car - so that's on the To do list too... just need a warm day.....
Soundeng is offline
post #13 of 23 (permalink) Old 02-26-2019, 04:56 AM
Quoted: 768 Post(s)
I have had 3 bad coils lately. After the first one, I replaced all 3, and then one of those went bad, 6 months later a second new one went bad. Engine lost power and when shutting it off and restarting, it ran OK for a bit, then shut down the cylinder again. A new coil did the trick (after replacing spark plugs first) The Denso long life plugs go roughly 100k miles, the standard ones go about 30K miles.
A little Marvel Mystery Oil never hurts!!
Smart Bob likes this.
jimvw57 is offline
post #14 of 23 (permalink) Old 02-26-2019, 01:36 PM
10 Year supporting member
1983JZR3W's Avatar
Quoted: 264 Post(s)
Were the coils original smart units or the red ones Smart Madness sells? I was planning to buy a new set from SM, but I will reconsider it if you had trouble with them.
1983JZR3W is offline
post #15 of 23 (permalink) Old 02-26-2019, 05:20 PM
Quoted: 768 Post(s)
first bad one was a stock coil with 112k miles on it, second one was a SM red coil about 3 days old, last one was a SM red coil with 7 months on it, about 35k miles. Smart Madness did replace the coils extremely fast and they do have a lifetime warranty on them. Price is real reasonable compared to the factory ones.
jimvw57 is offline
1983JZR3W (02-27-2019)
post #16 of 23 (permalink) Old 03-08-2019, 05:54 PM
Brabus's Avatar
Quoted: 15 Post(s)
I have a 2009 Smart with 11,000 miles on it. It started misfiring today for the first time on cylinder 1. Engine code P0301. I bought some HEET in the yellow bottle as I thought well I filled up with gas yesterday and maybe it's bad gas, but I feel like if it were bad gas then it'd be less predictable when it's sputtering. It sputters when shifting between 2nd and 3rd and when you're letting off the gas then reapplying the gas, especially at speeds of 45mph or higher.
Not really sure what to replace with such low miles. Spark plugs aren't suppose to be replaced until 30k miles. Hmm.
Brabus is offline
post #17 of 23 (permalink) Old 03-08-2019, 06:02 PM
Smart Bob's Avatar
Quoted: 173 Post(s)
I would administer a double dose of Marvel Mystery Oil to the gas tank and take the car out for a drive on an expressway. If this doesn't work check the coil and if you remove the spark plugs, I would do a compression test.
Smart cars will carbon up on the intake valves if driven on short trips at slow speeds for a protracted period of time.
Smart Bob is offline
The Following User Says Thank You to Smart Bob For This Useful Post:
Brabus (03-12-2019)
post #18 of 23 (permalink) Old 03-12-2019, 03:53 PM
Brabus's Avatar
Quoted: 15 Post(s)
I guess tomorrow is my time. I have to get my hair cut tomorrow which is a 30 minute commute on I-95. I normally take my sedan, but I'll do the mystery oil. Fingers crossed I don't get stalled out on I-95. My hair really needs a cut.
There seems to be more than one mystery oil product.
There's the MM12R product that comes in 16 ounce or 32 ounce. I suspect a double dose for a Smart car would be the 16 ounce due to the 8-9 gallon gas tank?
Then they have product called Ultimate which comes in a 12 ounce bottle, which is part number 50665.
I guess if this doesn't work, then I could try to swap the cylinder 1coil from my 2008 Passion onto my 2009 Brabus to see if it's a bad coil without having to buy a coil to find out. I don't have the testing tools to figure out if it's bad compression or a bad coil, not sure if AdvanceAuto or Autozone loans those tools.
Brabus is offline
post #19 of 23 (permalink) Old 03-12-2019, 04:39 PM
Brabus's Avatar
Quoted: 15 Post(s)
So the MM12R MM13R says to use 4 ounces per 10 gallons of fuel and for oil it says to replace up to 20% of oil with MMO. I guess I'll buy the 32 ounce, add 7 ounces to the fuel and pour the rest into the engine without replacing the oil. It's about a 3.5 quart car, so 22 ounces would be 20%.
Okay, I answered my question. Hopefully being overfilled by 25 ounces of oil won't too detrimental. I really don't feel like dumping oil just to put in MMO.
Brabus is offline
post #20 of 23 (permalink) Old 03-13-2019, 11:04 AM
Brabus's Avatar
Quoted: 15 Post(s)
Car is running like new again. I purchased the Marvel Mystery Oil in the 32 ounce size. Put 7 ounces in the gas (full tank) and 25 ounces in the engine. Drove it on I95, it puttered some for the first 5 miles, then cleared right up and drove it an additional 45 miles without any sign of engine troubles. Best $6 I ever spent. Thank you for solving my problem Bob.
I have been driving the car short distances over the past 18 months, rarely ever going further than 4 miles on the highway at any given trip. I also sometimes put in regular unleaded in the car instead of premium when the prices are 60-70 cents higher, maybe that's contributed to the carbon build-up.
jwight and Miss Mercedes like this.
Brabus is offline
The Following 2 Users Say Thank You to Brabus For This Useful Post:
Miss Mercedes (03-13-2019), Smart Bob (03-13-2019)
For Sale: 2006 fortwo passion coupe not running hoov23 smart Vehicle Marketplace 2 11-11-2017 07:26 AM
Rough Idle and Running mbiskie smart Operation and Maintenance 12 01-25-2016 12:44 PM
2008 Smart Fortwo FOR SALE. NOT RUNNING xavif310 California Chapter 4 08-09-2015 11:00 AM
2008 Smart Fortwo Gasoline Engine + Transmission (Running Condition) SmartRT smart Parts Marketplace 0 08-01-2013 08:26 PM
Smart : Fortwo Passion Heated Seats 2008 Smart Car Fortwo LOADED Great price MINT! Smart Cars For Sale Archive/obsolete (?) threads 1 01-31-2009 03:17 PM
