Smart Car Forums
Smart Car Forums (https://www.smartcarofamerica.com/forums/)
-   smart fortwo (451 - US vehicle) (https://www.smartcarofamerica.com/forums/f27/)
-   -   2009 Passion cabriolet - top shrank? (https://www.smartcarofamerica.com/forums/f27/2009-passion-cabriolet-top-shrank-154346/)
oldmanmagnet 06-13-2019 07:13 PM
It started out with my convertible top not latching completely. One day, it got stuck in the half down position.
I wound up taking it to the dealer. They switched out the convertible top motor and switch. They also said my top had shrunk, and quoted about $4000 to replace the soft top.
For now, the top is forced closed and latched but there’s a 1/4” gap. Is there any way to stretch the top back into position?
Thanks in advance.
Goofybutsane 06-14-2019 01:12 AM
I know you can take out the back third brake light and from the inside there’s about 4 bolts holding the plastic wing on and once that’s off in the corner there are nylon straps you can follow to the rear corner to some bolts if you loosen them you can relieve some tension to go forward and backwards. I had to tighten mine not long ago cause my top was doing a lot of flapping in the wind
dhlairbusb4 06-14-2019 05:12 AM
Hey Goofy, by any chance do you have any pics of that procedure... my top seems to do the same.
dave... crazy maybe, but Smart 2!
Goofybutsane 06-14-2019 08:08 AM
Sorry no pics but pretty easy once the plastic wing is off. If you put the top back about 30% you can follow those straps all the way back to the bolt under the wing. Then close the top back loosen the bolt and pull the strap snug and tighten. If you go to tight with them then the top will struggle to close so you have to find that happy middle
dhlairbusb4 06-15-2019 04:45 AM
Many thanks... I will check it out!
Powered by vBulletin® Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
