correct oil and filter for 2008 Passion - Page 2 - Smart Car Forums
 6Likes
post #11 of 14 (permalink) Old 04-11-2019, 12:06 PM
smark's Avatar
Quoted: 652 Post(s)
I have to different sized oil filter cap wrenches. One for the stock, smart oil filter, the other for the Mobil 1. Body shell, just a little different.
smark is online now
post #12 of 14 (permalink) Old 04-12-2019, 04:17 PM
Dougg's Avatar
Since any smart dealer is at least 2hrs drive, I opted for a local solution for the first service on my 2008 Passion... The Yamaha motorcycle dealer. I got a Yamaha 5DM-13440-00 oil filter (that cross-refs with Mitsubishi's Tokyo Roki filter) and 10 years ago it went for $17.23.
The stock filter is for a Mitsubishi motor (the Smart part # is A-132-180-00-10: the Mitsubishi part # is 1230A040) the copper ring can be re-used (part # A-018-997-44-45) The drain plug screen needs to be washed in solvent (solvent available at any parts store) be sure the screen is dry before re-installing- it does not need to be replaced. Minimum oil spec is 229.9, I live in a moderate-cool climate and used 3.5 qt Mobil 1 10w40.
BTW, a longer oil filter will reduce ground clearance, so that's a consideration.
The transaxle drain and fill:
Facing the rear, the plug on the lower right side of the diff is the drain... on the left and several inches higher is the fill plug.... Use Mobil 1 75w90 gear oil (2.4 qts).
Dougg is offline
post #13 of 14 (permalink) Old 04-12-2019, 05:06 PM
Quoted: 69 Post(s)
You need to use a GL-4 gear oil in the transmission.
Mobil1 75W-90 is GL-5, which is bad for brass synchros.
mattwithcats is offline
post #14 of 14 (permalink) Old 04-12-2019, 05:10 PM
smark's Avatar
Quoted: 652 Post(s)
This is my smart service advisor recommended. For the transmission oil. He used it, in all 3 of his smart cars.
smark is online now
Oil filter tool and oil type? Rasrreynolds1 smart Operation and Maintenance 5 08-16-2018 07:57 PM
Magnetic oil drain plug and oil filter magnets? mvaldes smart Operation and Maintenance 47 06-19-2013 10:30 PM
451 Oil Filter & Air Filter Smart Pitstop Vendor Deals 0 07-31-2009 10:30 AM
