Smart Car Forums
Smart Car Forums (https://www.smartcarofamerica.com/forums/)
-   smart fortwo (451 - US vehicle) (https://www.smartcarofamerica.com/forums/f27/)
-   -   Headlights (https://www.smartcarofamerica.com/forums/f27/headlights-154412/)
dhlairbusb4 06-21-2019 01:54 PM
Headlights
Hey everyone.
I am looking to purchase some new headlights for my 09 451, not because I am passionate about them... its they simply suck!
Adjusting is not easy, as the driver side Hi beam goes into the trees when the low beams are even and correct.
Also the inside of the lens is cruddy.
So, anyone have a good source? Madness, Ebay, Amazing river, and the C list... not helping me too much.
A real nice used set, or new set is what I am looking for, price at the MB parts is over 600... yikes! Surely
someone has dealt with this issue already, and I really would like to know what you did.
On another note...
I am getting ready to remove the gear shift motors for a cleaning, changing the tranny fluid also with MT90. Also installing the Madness
cold air intake hose, and tossing the air box that is in there now. I just hope I do not have to use the Jaws of life to get it out!
I got the rear wheel camber pretty much zeroed out, looks much better... and I think handles better too!
jwight 06-21-2019 03:01 PM
Just my .02 but the stock H7 lights are more than enough. It sounds like something is broken in one of your headlights if the "Hi beam goes into the trees." High beams are not adjustable anyway. There's a drivers side assembly on eBay for $125: https://www.ebay.com/itm/2008-2015-S...0AAOSw1~Nc0H33 :)
jimvw57 06-21-2019 03:26 PM
if the inside of the assembly is 'cruddy' then chances are it is broken and allowing debris in there. The high beam mount is extremely fragile and will break easily. Had that happen to a replacement headlight I got when I hit a deer. There isn't a good way to repair it, just replace it.
Adding any sort of glue will fog the bulb and cause it to overheat. It is possible the bulb was installed upside down and the tab is making it shine straight up (Hi beam) so you could check that out. If the clip that holds it in place is hard to open up, the bulb is in wrong. (been there)
twcom 06-22-2019 04:18 AM
Originally Posted by dhlairbusb4 (Post 1668758)
Hey everyone.
What did you do to achieve that.
dhlairbusb4 06-22-2019 04:44 AM
After much research here, and on evolution, and discovering that the wedges are no longer available... this seemed like the only other way to eliminate the neg-camber.
Removed the wheel and hub, then look behind the plate that the brake is mounted to, there are four bolts, I think they are called E bolts, you can get the sockets at Harbor Freight. Remove the top two, and loosen the bottom two... then insert the washers over the bolt, between the plate and the mounting pad, then tighten everything up. You will also need to remove the large bolt on the end of the transaxle, then you can push it in towards the center of the car to get more room for the E bolts. I used a shallow socket, with a 10" extension.
There are lots of pics, but you have to search to find them. I wish I would have taken pics during the process, but maybe next time.
dhlairbusb4 06-22-2019 05:22 AM
OK, got the headlights ordered.....
Now, anybody done a R&R on these before???
jimvw57 06-22-2019 05:38 AM
Just a few times.. Usually you can sneak a torx driver behind the fender to get to the screws that hold them in place, 3 of them I believe, #25 torx (or #27 I forget)
dhlairbusb4 06-22-2019 07:08 AM
Jim, did you remove the fenders, like evolutions says to do?
If it can be done with out removing, that would make it much easier.
jwight 06-22-2019 07:56 AM
dhlairbusb4 06-22-2019 10:43 AM
Thanks JW...
I am hoping the new lights arrive in the next couple of days.
Yesterday Madness told me that my intake tube was on backorder.... so I am delaying the
shift motor cleaning, tranny fluid change until that arrives.
dave
Powered by vBulletin® Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
