P0915 Code (Gear Shift Position Circuit Range/Performance) - Smart Car Forums
 1Likes
  • 1 Post By albertlastsmart
post #1 of 4 (permalink) Old 05-21-2019, 04:54 PM Thread Starter
Hello everyone... new to the forum in search of answers.
I have 2008 with 66,000 miles on it with the following issues:
- 3 Bars flashing
- after doing a reset, I can see the gears shift
- if I get it in D just for a bit the triangle light keeps flashing and eventually goes back to the three bars.
- P0915 Code (Gear Shift Position Circuit Range/Performance) once I ran my OBD connection
Top Reported Fix - Replace clutch actuator Motor M18 w/P0914,P1800
If i play around with the shifter, I can get the car started and on the display I can see P, N, R, D, and 1 once i move the gears. R is some what hard to get into to show on the display.
I've taken apart the clutch actuator and seems to be nothing broken in it but not sure. I've been reading up on this and it's look like a common issue with the actuator but looking on what is the best way to confirm it. Any help would be appreciative.
I took the actuator cover off and can see it functioning. Will see how I can upload a video of it.
Following verified:
- battery fully charged
- brake light switch is engaged.
Thanks in advance for the help!
Pardesi is offline
post #2 of 4 (permalink) Old 05-21-2019, 10:13 PM
Quoted: 776 Post(s)
There was a software upgrade back then for the transmission that you may not have gotten. Unfortunately the dealer is the only place to get it and they will most likely charge for it since it has been so long ago.
jimvw57 is offline
post #3 of 4 (permalink) Old 05-22-2019, 07:48 AM
Quoted: 15 Post(s)
Call before upgrade.............
If you call the smartcenter/stealership,and give your car's VIN number,they SHOULD be able to tell if your car
has had the latest software upgrades.....................
Smart Bob likes this.
albertlastsmart is offline
post #4 of 4 (permalink) Old 05-22-2019, 08:51 PM Thread Starter
Thanks, will give them a call and see what has been done.
Pardesi is offline
P0805 Clutch Position Sensor Circuit problem chieftmc smart Operation and Maintenance 78 11-12-2018 05:13 PM
P0018 Crankshaft Position/Camshaft Position Correlation Bank 2 Sensor A(incl part #s) mrgreat smart Operation and Maintenance 14 07-24-2011 08:47 PM
obdii code P0887 TCM Power Relay Control Circuit High pitstopautoinc smart Operation and Maintenance 6 09-04-2009 02:37 PM
Say good-bye to Circuit City JPaul Tech & Gadgets 15 11-14-2008 12:18 PM
Circuit City includes smart jwight Tech & Gadgets 23 07-21-2008 05:19 AM
