Revived a 2009 451. It's alive! But need help! - Page 2 - Smart Car Forums
post #11 of 16 (permalink) Old 06-12-2019, 01:55 PM
King of Smart Gadgetry
DreamCarOwner's Avatar
Quoted: 313 Post(s)
It is possible that your TPMS just needs a reset. Air your back tires up to 34 lbs and the front ones to 29. Then go turn the ignition switch to the on position. Then push in the TPMS button for about 10 seconds or so. It will flash and when you let off the button it will reset. Now drive the car around the block a couple of times and see if the light comes back on. If it does there's a good chance that one or more of your tire sensor batteries are dead. Tire sensors only transmit when the tire is in motion. They have an inertia switch inside. The TMPS will warn you if a tire pressure increases or decreases about 4 to 5 pounds over or under the amount of air that you just put in at your reset. It only reads pressure variance not actual lbs. Once it is reset and it stays off for a long time you can air up the faulty tire that is low and the light will go out on it's own because you aired back up to your "reset set" pressure.
As far as your P050A shows on my Smart code list as Cold Start Idle Air Control System Performance. It's a generic code for all models. But my list has been wrong before. DCO
DreamCarOwner is offline
post #12 of 16 (permalink) Old 06-12-2019, 08:48 PM Thread Starter
I'll figger this car out
Quoted: 15 Post(s)
Thanks for your help! I will do work on thye TPMS after I find a way to get the transmission to engage and move the car. Then I have to figure nout how to troubleshoot the cold start Idle Air Control System Performance unit.
If anyone has a non Star scanner that has/can do the diagnosis/reset for my vehicle, please let me know. It will cost me to ship the car to a smart service station in Indiana since there appear to be none in Michigan.
Thanks to everyone for the help so far. I tow the car to my house Friday, and the in-depth work starts. That's why I'm looking for some way to get the transmission to engage. Then the exhaust holes are repaired.
I'd like to find info to identify and test all sensors, as well. THANKS!
strelnik is offline
post #13 of 16 (permalink) Old 06-13-2019, 06:02 AM
Mod ♥ 450/451/453 + Motos
Miss Mercedes's Avatar
Quoted: 164 Post(s)
So first thing I'd do is clear the codes and see what comes back. It does take some engine cycles for codes to go away on their own. Any old scanner should be able to clear the codes. Do it with ignition on and engine off.
If you can push the car in Neutral, I would assume your brakes are not locked up. The ABS and ESP fault may be reluctor rings. Car is high mileage, lives in Michigan, and ten years old, good chance at least one of them is just a pile of rust.
If you see D or R when you put it in gear, but all the car does is buck, it may be worth it to remove the clutch actuator and give it a good cleaning and lubing.
Miss Mercedes is online now
The Following User Says Thank You to Miss Mercedes For This Useful Post:
strelnik (07-01-2019)
post #14 of 16 (permalink) Old 06-15-2019, 07:18 PM
Quoted: 1 Post(s)
I'm from Michigan as well, we have a smart center in Ann arbor. It's the same Mercedes dealer but they also handle smart car servicing. Did you check if your brakes have locked up? Has the car been sitting for a long time?. If the car is showing the selected gear on the screen but doesn't move then either the clutch is worn completely or some other thing is wrong.
I use the icarsoft scanner, I bought it of amazing for $100 or so. It works well and is able to detect all of the modules in our smart cars.
The TPMS could be any number of things, however it's not critical, I suggest you fix the transmission and abs before attempting to fix it.
ohabbal is offline
post #15 of 16 (permalink) Old 07-01-2019, 07:23 AM Thread Starter
Quoted: 15 Post(s)
I saw what you're saying. My big problem with this car is that I have no manual and need to get the codes cleared. None cleared when I used the iCarsoft890 so I'm sending it back.
Getting a repair manual and parts manual for this car is what I really need and am willing to pay for them.
Thanks for any and all suggestions
strelnik is offline
post #16 of 16 (permalink) Old 07-01-2019, 07:26 AM Thread Starter
Quoted: 15 Post(s)
Thanks for the advice. How do I locate the reluctor rings? What's a good parts source?
strelnik is offline
