Spark plugs - Page 2 - Smart Car Forums
 3Likes
post #11 of 14 (permalink) Old 02-18-2019, 11:30 AM
magilly00's Avatar
Quoted: 47 Post(s)
The bolt is a 6mm-1.0x20 mm
magilly00 is offline
post #12 of 14 (permalink) Old 02-18-2019, 11:39 AM
magilly00's Avatar
Quoted: 47 Post(s)
Originally Posted by jimvw57 View Post
I have replaced a lot of plugs, and other than the heads of the bolts getting rusty, Never had a problem with breaking a bolt. I have replaced them with SS ones just to avoid the rust (gotta love Minnesota winters)
I am 2 for 2 with the bolt heads snapping off during spark plug changes, and I am a bit hesitant to change the plugs in my other two smart cars. If your not too busy I can let you remove the bolts on the next 2, maybe you will have better luck than me.
post #13 of 14 (permalink) Old 02-18-2019, 11:54 AM
Quoted: 52 Post(s)
Actually SS bolts in aluminum is not a good idea. Take a look at any galvanic series chart of metals to see why.
https://en.wikipedia.org/wiki/Galvanic_series
https://www.corrosionpedia.com/an-in...rrosion/2/1403
Aluminum being the less noble metal than SS it will corrode, especially so, given the large potential difference between the two metals. I'd recommend using a zinc-plated fastener as the zinc is closer to aluminum on the galvanic series so the combination is less prone to corrosion. Additionally in this case the zinc becomes the sacrificial anode, not the aluminum.
There is a reason that manufacturers' use zinc-plated fasteners with aluminum. If you must use SS, apply an anti-seize compound, preferably one containing zinc.
~toaster
toaster is offline
The Following 2 Users Say Thank You to toaster For This Useful Post:
magilly00 (02-18-2019), Smart Bob (02-18-2019)
post #14 of 14 (permalink) Old 02-18-2019, 08:44 PM
Quoted: 70 Post(s)
I put copper anti seize on the bolts, and spark plug threads.
http://www.itwconsumer.com/versachem...cket%20pack-81
I also soaked the bolt in Pb Blaster (used a q-tip to apply) daily for two weeks, before trying to remove...
Smart Bob likes this.
mattwithcats is offline
Pulstar spark plugs chieftmc smart Operation and Maintenance 19 08-28-2014 09:22 PM
451 spark plugs jwight smart Operation and Maintenance 24 01-02-2014 04:31 PM
Change Brake fl @ 20k and spark plugs @ 30k aclinml smart Operation and Maintenance 8 10-25-2011 06:25 PM
Spark Plugs At 30k ? a2jack smart Operation and Maintenance 17 10-11-2009 04:08 PM
