Video: How to Install Smart ForTwo Dome Light LEDs! See Comparison Photos! - Smart Car Forums
post #1 of 4 (permalink) Old 06-16-2015, 07:04 AM Thread Starter
Supporting Vendor
Diode Dynamics's Avatar
Quoted: 19 Post(s)
Lightbulb Video: How to Install Smart ForTwo Dome Light LEDs! See Comparison Photos!
Smart Fortwo Dome Light LED
At Diode Dynamics, we carry a full line of LED bulbs, to replace your dome lights, license plate lights, trunk light, turn signals, and more!
We carry the brightest, highest-quality bulbs at the lowest prices. Your order will ship same day, and we're here if you need us for support and service. These LED bulbs are designed by us here in St. Louis, and every bulb carries with it a three-year limited warranty.
Your dome light, or single light located in the center of the ceiling, uses an incandescent bulb from the factory, giving it a yellowish color. By replacing with an LED, you can add a luxurious and modern look to your Smart Car, with a cool white color, just like the lights on newer luxury vehicles. You can also increase the brightness with SMF4 or SMD12 Board, to improve the performance of your dome light.
The installation is 100% plug-and-play, just replace your factory bulb!
Bulb Design:
SMF2: This bulb has a standard festoon base, with two forward-facing 5050-size Epistar SMDs. Direct replacement, plug and play.
SMF4: Standard festoon base, with four 5050-size Epistar SMD chips arranged on a rectangular panel. Direct replacement, plug and play.
SMD12 Board: This is an LED panel, fitted with 12 5050-size Epistar SMD chips. Comes with spring-loaded festoon-style adapter for direct installation. Plug the adapter into the bulb socket, then just stick the board in place with the mounting adhesive pad. The board-and-adapter design allows for extremely high brightness compared to a simple bulb.
Brightness
SMF2: (16 lumens) Slightly lower brightness than OEM bulbs, but still provides the crisp, modern color of LED.
SMF4: (56 lumens) Slightly higher brightness than OEM bulbs.
SMD12 Board: (118 lumens) Much brighter than OEM bulbs. These are bright!
Lumens: BUYER BEWARE! Most sellers just provide "calculated" lumen numbers, based on the maximum potential brightness of the LED chips on the bulb. For example, if a bulb has five 10-lumen chips, they will rate it at 50 lumens. However, this is not accurate, as the design of an LED bulb does not get rid of heat fast enough to run the LEDs at maximum.
These "calculated" lumen ratings are much, much higher than the true, measured light output, so it will look like competitors' bulbs are brighter than ours. This is because Diode Dynamics does not provide inflated "calculated" numbers; we believe it is misleading. We test the actual brightness of the bulbs in our lab, to provide real lumen output measurements. Our measurements are accurate, but they are usually much lower than the misleading "calculated" figures.
All products by Diode Dynamics are backed by a 30-day satisfaction guarantee and a three-year limited warranty.[/CENTER]
2010-2015+ Smart ForTwo Dome Light LED
Questions? Feel free to ask here, PM, email [email protected] or call us: (314) 205-3033
*PM us for the free-shipping code* (U.S. forum members only)
Thank you!
Nick C.
Diode Dynamics
Diode Dynamics is offline
post #2 of 4 (permalink) Old 09-10-2015, 06:24 AM Thread Starter
Supporting Vendor
Quoted: 19 Post(s)
post #3 of 4 (permalink) Old 01-14-2016, 06:51 AM Thread Starter
Supporting Vendor
Quoted: 19 Post(s)
We have several color options available as well!
Red, Blue, Green etc..
Check out the listing for more information: Dome Light LED for 2010-2014 Smart Fortwo - Fortwo - Smart - Products By Vehicle
Thanks!
Nick C.
post #4 of 4 (permalink) Old 05-02-2016, 07:39 AM Thread Starter
Supporting Vendor
Quoted: 19 Post(s)
Don't forget to send us a PM for the free-shipping code!
(U.S. members only)
Thank you,
Nick C.
Smart Fortwo Tail Light LEDs! Several Bulb Models! See Output Comparison Photos Diode Dynamics Diode Dynamics 5 06-20-2016 08:43 AM
Smart Passion Fortwo License Plate LEDs! See Install Video! Same-Day Shipping! Diode Dynamics Diode Dynamics 11 02-22-2016 06:42 AM
2014 Smart Passion Fortwo in the Studio for Comparison Photos and Testing! Diode Dynamics Diode Dynamics 6 05-18-2015 09:38 AM
smart car Dome Light SMD Replacement Bulb Panel MADNESSMIKE Interior & Exterior Styling 34 12-21-2013 04:51 AM
451 smart fortwo | How do you pop the DOME light out? SMART smart Modifications 2 03-25-2008 05:44 AM
