451 hose info - radiator hose wear - Page 9 - Smart Car Forums
 10Likes
post #81 of 84 (permalink) Old 08-10-2014, 06:47 AM
Quoted: 21 Post(s)
Originally Posted by toaster View Post
Do you know how the engine was moved back? Looking at the engine mounts, I don't see any forward/backward adjustment. Was it the engine cradle that was moved?
~toaster
Toaster, I did not see them in the actual process of moving the engine mounting.
I was there under the car as they showed me the loose radiator and condenser the last MB smart center left after replacing the entire A/C hose system.
They were showing me that there was now clearance and my hose did not touch and they did not touch the hose, itself....cause I asked them if they shortened it. They did NOT shorten it, they just explained how the motor mounts wear, and drop the engine as they wear. So, they re positioned the motor, and gave the clearance that way. Maybe there is a tech on this forum familiar with this particular fix for the hose rubbing . I am sure this is quicker for the tech on a slight rub like mine, not needing a replacement, to do this repositioning.
Hope this kinda helps, but again, I wasn't there when they did the actual work. This was a post-op visit under the car with the tech and the service manager.
gkalexdc is offline
post #82 of 84 (permalink) Old 08-25-2015, 08:59 AM
Quoted: 10 Post(s)
radiator hose wear
Originally Posted by GiantKiller View Post
brought it up @nationals to service guy and he said he knew about it. I bought new hoses. (I was one of the lucky ones with rubing hose) the replace ment hose was about 1/8" shorter on engine side I shortened the worn 1 and put it back on to see and it fixed the clearance prob. So if yours is up against the frame an not worn yet just cut a little off the end and it'll be good. The differance is very small. But it is enough to put it up against the frame.And engine shake wears it out.
Hey I'm one of the unlucky ones also.. Do you happen to have the part number or a link for the replacement hose? I need to order one so I can get this fixed but don't want to order the wrong one.
-Garrett
justsailin is offline
post #83 of 84 (permalink) Old 07-20-2018, 09:50 AM
wahi's Avatar
Quoted: 15 Post(s)
It finally happened! Cheewawa (2008, 2nd engine) at 207070 miles wore a hole in the hose in that exact spot. Now how do I go about getting a new hose (what part number?) and more importantly, how to get to it.... evilution's site and Faq101 both have nothing on this repair... any ideas?
wahi is offline
post #84 of 84 (permalink) Old 07-20-2018, 11:43 AM
Bohemian Moderator 451gas
Quoted: 78 Post(s)
Here's all I could find; you'll have to figure out which one is the hose in question:
Rear Hose
To Thermostat
1322030102
By-Pass Hose
1322030002
To Water Outlet
1322031402
wahi and Jo e Lefors like this.
jwight is offline
The Following 2 Users Say Thank You to jwight For This Useful Post:
Jo e Lefors (07-21-2018), wahi (07-20-2018)
Forge Motorsport Intake Hose tigerwong58 smart Modifications 36 05-25-2013 10:02 PM
Best silicone intake hose?? davemt74 smart Modifications 13 01-03-2010 03:37 PM
for sale (Re: silicon intake hose) fts1966 Archive/obsolete (?) threads 4 03-27-2009 06:59 PM
Silicone intake hose JimDantin smart Modifications 19 12-03-2008 02:35 AM
Finally found a dealer that didn't hose me - at least, not yet doogster smart General Discussion 10 05-13-2008 06:51 PM
