Clutch issues - Smart Car Forums
post #1 of 8 (permalink) Old 06-05-2014, 08:47 AM Thread Starter
Clutch issues
Does anyone know what kind of grease or oil is used in the clutch housing?
momhealy is offline
post #2 of 8 (permalink) Old 06-05-2014, 08:52 AM
Quoted: 6 Post(s)
There is grease on the splines of the input shaft, and maybe some on the receiving end of the clutch lever and actuator rod.
As for gear oil in the gearbox, most replace it with Redline MT90.
tablist180 is offline
post #3 of 8 (permalink) Old 06-05-2014, 01:45 PM
BB Benz's Avatar
Quoted: 230 Post(s)
What kind of issues are you having that you should ask?
BB Benz is offline
post #4 of 8 (permalink) Old 06-05-2014, 01:59 PM
Quoted: 6 Post(s)
post #5 of 8 (permalink) Old 06-05-2014, 06:14 PM Thread Starter
When you take off from a stop, sometimes the car goes into neutral and shuts down for 5 minutes. Then it starts and it's like nothing happened. The error code says it's the clutch accentuator sensor. I read somewhere that if you raise the car up and remove the boot, you can fill it with grease and it should run better. I used 3 in oen oil and it only lasted about 3 months and it has started doing it again. Thought I might be using the wrong thing.
momhealy is offline
post #6 of 8 (permalink) Old 06-05-2014, 06:17 PM Thread Starter
Yes, I know that, but I found out if you remove the boot from underneath and fill it with grease, the problem was solved for about 3-4 months. I don't want to put money into something the dealerships told me they weren't even sure where the sensor was located.
momhealy is offline
post #7 of 8 (permalink) Old 06-05-2014, 06:34 PM Thread Starter
Redline MT90 what? Is it GL 4 or GL 5? what about MT90 75W90 GL4?
momhealy is offline
post #8 of 8 (permalink) Old 06-05-2014, 07:06 PM
To the XCAPEPOD!
rfernatt's Avatar
Quoted: 68 Post(s)
rfernatt is offline
Shifter issues daverivera smart General Discussion 1 06-08-2012 02:42 PM
Having issues littlefootann smart Operation and Maintenance 2 01-21-2010 09:07 AM
Suspension Issues WilyB smart Modifications 9 05-27-2009 09:09 AM
transmission issues freddyfatboy smart Operation and Maintenance 6 05-08-2008 04:34 PM
