New front wheel bearing and problems - Smart Car Forums
post #1 of 11 (permalink) Old 05-27-2013, 09:12 PM Thread Starter
Quoted: 799 Post(s)
OK, I got a call from a fellow smart owner who recently got a 2008 passion and has been working on it. He decided to take it to the dealer for a coolant flush. They also found a wheel bearing that was making some noise (RF) He asked them to give it the once over. They replaced the bearing and he was on his way. a few days later, he drove it on a short trip ( a few hundred miles) and he found the Right front brake disk was extremely HOT. Hot enough that you didn't want to touch it, while the Left front rotor was noticeably cooler. After returning home, He found them to be about the same temperature. The Right front brake is now making a grinding noise , I suspect the pad is gone.
The question is..... when the dealer replaced the bearing, wouldn't they have to remove the caliper and rotor? If so, it seems strange that it would have locked up shortly afterwards. And if the pad was close to the end of its life span, wouldn't they have said it needed replacement????
I haven't seen it yet but there seems to be some serious questions here. I would have expected more from a Mercedes/smart dealer. They did give him a loaner smart since they ended up keeping it overnight. Funny that they would give a Passion owner a Pure as a loaner vehicle.
I should mention that his car has around 90K miles on it so worn out brakes shouldn't be ruled out. They did have the opportunity to check it over, and brakes are easily checked...
jimvw57 is offline
post #2 of 11 (permalink) Old 05-27-2013, 10:17 PM
Quoted: 1 Post(s)
Yes, they would need to remove the caliper and rotor to do a bearing. Also while doing the bearing, if he needed brakes they would have let him know. Its also good to note that the side that got hot was on the same side as the one that the bearing was changed.
Did he not notice any pulling? Normally if the brakes were locked up, you would notice pulling (in this case to the right). I would definitely hold the dealer accountable for piss poor work.
Brutal Force is offline
The Following User Says Thank You to Brutal Force For This Useful Post:
Pee-wee Germa (05-28-2013)
post #3 of 11 (permalink) Old 05-28-2013, 04:59 AM
BARNEY O's Avatar
Quoted: 123 Post(s)
Can't replace bearing only... The guy must of received bearing and lower strut casting assembly..
BARNEY O is offline
The Following 4 Users Say Thank You to BARNEY O For This Useful Post:
chieftmc (05-28-2013), jefferios (05-28-2013), jwight (05-28-2013), Miss Mercedes (05-28-2013)
post #4 of 11 (permalink) Old 05-28-2013, 06:34 AM
Quoted: 84 Post(s)
Or not
chieftmc is offline
post #5 of 11 (permalink) Old 05-28-2013, 06:36 AM Thread Starter
Quoted: 799 Post(s)
Sorry, he did say they replaced the 'steering knuckle' (their words)
He didn't say he noticed a pull and he would have noticed that I believe. Sounds to me like they didn't clean up tha calipers before putting them back in place.
The dealer also mentioned a cracked flex pipe, and the owner did think it was a bit louder than my Pure. Anybody got a leftover exhaust from an upgrade??
jimvw57 is offline
post #6 of 11 (permalink) Old 05-28-2013, 06:49 AM
wahi's Avatar
Quoted: 15 Post(s)
I do, but not with me right now. Maybe by 20th June ...
wahi is offline
post #7 of 11 (permalink) Old 05-28-2013, 07:26 AM
imcquade's Avatar
....sometimes you just get caught short :-(
On my Jeep a few years ago....
I had to take the calipers off to do some work
When I put the caliper back on.... a few miles down the road I noticed a stink
When I pulled over my brakes where damn near on fire....
The stupid caliper was seizing on
I didn't do anything to cause it
Just timing.... (maybe a bit of grime got in, who knows)
So I changed the caliper and off I went :-)
Some times its not some bodies fault is just the way it works out
Cheers
Ian
imcquade is offline
post #8 of 11 (permalink) Old 05-28-2013, 06:40 PM
Quoted: 9 Post(s)
I need one of those soon too, Dealer said the "kit" was over $200
My smart has the sound of an aftermarket system.
forestacademy is offline
post #9 of 11 (permalink) Old 05-28-2013, 07:02 PM
Mod ♥ 450/451/453 + Motos
Miss Mercedes's Avatar
Quoted: 164 Post(s)
Smart Madness usually has take offs from upgrades, give them a call!
Miss Mercedes is offline
post #10 of 11 (permalink) Old 05-29-2013, 04:39 AM
Quoted: 3 Post(s)
Jim,was this done at Rochester or elsewhere?
SmartJoeMN is offline
Front wheel bearing noise jackblds Interior & Exterior 67 09-28-2015 07:01 AM
Front wheel spacers vs wider front wheels - Comparable handling improvements? ilomax smart Modifications 24 02-03-2013 09:19 AM
2009 cabrio front wheel bearing itshercar smart Operation and Maintenance 6 01-14-2013 07:47 AM
08 wheel bearing/ spindle accomsrazor Archive/obsolete (?) threads 1 05-02-2012 05:33 AM
Front Wheel Bearing john j shaw smart Operation and Maintenance 12 02-10-2012 08:32 AM
