P0805 Clutch Position Sensor Circuit problem - Smart Car Forums
 4Likes
post #1 of 79 (permalink) Old 03-13-2012, 04:32 PM Thread Starter
Quoted: 84 Post(s)
I just got a P0805 tonight rolling into my driveway
Selector shows in gear... motor revs .... no movement :eek:
Any suggestions ??????
chief.............always in need
chieftmc is offline
post #2 of 79 (permalink) Old 03-13-2012, 04:34 PM Thread Starter
Quoted: 84 Post(s)
Well,
Apparently a SG can NOT reset a P0805 code
I shut off car for 1/2 an hour.....restart....it now drives.... BUT ..... still have CEL P0805
Any help from anyone smarter than me (that's ALL of you ) ????
I have disconnected the battery.....will wait 1/2 hour and see !!!
chief............still needy
chieftmc is offline
post #3 of 79 (permalink) Old 03-13-2012, 04:38 PM
mhornfeck72205's Avatar
Quoted: 6 Post(s)
sounds like clutch actuator! :O See if its stuck in its extended position. that'd keep it from engaging.
*edit* also, you can try and hear if its functioning by putting it on accessory power, press the brake, put it in +/-, and shifting between 1 and 2 while stationary.
mhornfeck72205 is offline
post #4 of 79 (permalink) Old 03-13-2012, 04:55 PM
Terminated
Not sure about the actual problem, but how do you know that the SG isn't resetting the code? If the problem still exists, the light would come back on immediately and store the code again.
I remember one time a friend of mine had a throttle position sensor code on his car and he asked me to reset it with my scan tool. As soon as I reset the code, it stored the code again immediately because the voltage was way out of the specified range.
misfitsailor likes this.
Critical Thinker is offline
The Following User Says Thank You to Critical Thinker For This Useful Post:
chieftmc (03-13-2012)
post #5 of 79 (permalink) Old 03-13-2012, 05:05 PM Thread Starter
Quoted: 84 Post(s)
The Actuator is working, took car out and it shifts fine....just still have CEL P0805 !
chieftmc is offline
post #6 of 79 (permalink) Old 03-13-2012, 05:05 PM Thread Starter
Quoted: 84 Post(s)
Guess that's possible....didn't think of it...thanks
chieftmc is offline
post #7 of 79 (permalink) Old 03-13-2012, 06:07 PM Thread Starter
Quoted: 84 Post(s)
Update 1
Well, I disconnected the battery for about 1/2 an hour and all seems well.
The P0805 code has cleared. I did the "teach in" and took her for a spin
All seems well now....guess I'll see in the morning when I go to work
chief......... a little less needy now
chieftmc is offline
The Following User Says Thank You to chieftmc For This Useful Post:
Pee-wee Germa (03-13-2012)
post #8 of 79 (permalink) Old 03-13-2012, 09:52 PM
BB Benz's Avatar
Quoted: 230 Post(s)
Yes, Push it!
Your's has enough miles on it now to possibly need the moving in a bit adjustment of the clutch actuator maybe, like Blackandwhite08 did on his.
BB Benz is offline
post #9 of 79 (permalink) Old 03-13-2012, 10:24 PM
Quoted: 806 Post(s)
The SG will reset most codes, but some codes can not be reset. Had the same issue with my turbine shaft error. had to disconnect the battery for at least 1/2 hour to reset it. I ended up cleaning out all the wiring connectors I could find and using a bit of dielectric grease to seal them and the problem went away. (didn't even know I had a turbine in my car) Found the problem only happened if I washed the car or drove through big puddles. i could consistently drive 4.5 miles before it came back on again. It was a long weekend.
This sounds like a clutch actuator that needs cleaning and greasing (??)
jimvw57 is online now
post #10 of 79 (permalink) Old 03-13-2012, 10:45 PM
BB Benz's Avatar
Quoted: 230 Post(s)
Jim, did you finally figure out which connector fixed the turbine shaft error code?
BB Benz is offline
Clutch problems again: Error code P0805 just popped up unicycle smart General Discussion 45 05-01-2017 08:40 PM
How to replace the crankshaft position sensor rfernatt Technical "stickies" 20 11-13-2016 12:14 PM
Engine start question for the gearheads (crankshaft position sensor?) rfernatt smart Operation and Maintenance 17 05-24-2013 08:05 AM
Throttle Position Sensor jgspears smart Operation and Maintenance 0 10-09-2011 12:07 PM
P0018 Crankshaft Position/Camshaft Position Correlation Bank 2 Sensor A(incl part #s) mrgreat smart Operation and Maintenance 14 07-24-2011 08:47 PM
