Removing nub from door lock - removing key section - Smart Car Forums
 2Likes
  • 2 Post By jwight
post #1 of 8 (permalink) Old 08-13-2019, 02:58 PM Thread Starter
Quoted: 9 Post(s)
The outer section of the door nub broke off and i pushed the nub in further by mistake. How do i remove the key mount on the door to get that plastic piece out? Does taking the lock apart get access to the nub?
toecutter is offline
post #2 of 8 (permalink) Old 08-13-2019, 11:44 PM
Quoted: 12 Post(s)
Is this the little circular lock protector? If so they are cheap to buy so you could make a small hole and then screw in a small self tapper to pull it out with and then just replace it.
dolphinfreindly is offline
post #3 of 8 (permalink) Old 08-14-2019, 08:22 AM
aka 'smart-1'
ca smartone's Avatar
Quoted: 85 Post(s)
ca smartone is offline
post #4 of 8 (permalink) Old 08-15-2019, 04:41 PM Thread Starter
Quoted: 9 Post(s)
I drilled a hole through the plastic piece and tried to screw in a bolt to pull it out and it did not work. This was a few weeks ago. Now, i assume i need to take the lock out and take the metal cover off and reinstall.
post #5 of 8 (permalink) Old 08-15-2019, 11:31 PM
Quoted: 12 Post(s)
Do you have pics, it might make it easier to help
post #6 of 8 (permalink) Old 08-16-2019, 04:37 AM
Jo e Lefors's Avatar
Quoted: 202 Post(s)
I know what happen. The cap or cover broke off from the blade part that slides into the lock cylinder, and that part is jammed Down in the lock cylinder. Samething had happened when I got my car. My lock had to come out of the door and be taken apart to remove the piece of plastic jammed in the cylinder.
I wish I would have used a professional locksmith. I would be able to unlock my door with my key.
Good luck.
Jo e Lefors is offline
post #7 of 8 (permalink) Old 08-24-2019, 05:50 AM Thread Starter
Quoted: 9 Post(s)
Good luck.
Yea, thats what happen. How did you get the lock out?
post #8 of 8 (permalink) Old 08-24-2019, 08:05 AM
Bohemian Moderator 451gas
Quoted: 78 Post(s)
1 Door handle
2 Cover
3 Relay lever
4 Stator
5 Retaining spring
6 Spring
7 Lock cylinder
8 Bracket
9 Retaining spring
A Transmitter key
sokoloff and NW453 like this.
jwight is offline
