Replace old front springs - Smart Car Forums
 2Likes
  • 2 Post By stuberman
post #1 of 10 (permalink) Old 07-13-2019, 04:44 PM Thread Starter
stuberman's Avatar
Quoted: 5 Post(s)
My 2008 451 Passion is in its 12th year of all year driving on salted roads in the winter and humid summers. This winter the front end started making loud crunching sounds when turning sharply. I knew I would need to take apart the front end to figure out what was happening, but it also felt safe to drive for a few months until I had a vacation. I gave myself one week to tear apart the front end, figure out what needed to be replaced, order the needed parts and install them.
This is that story.
stuberman is offline
post #2 of 10 (permalink) Old 07-13-2019, 04:52 PM Thread Starter
stuberman's Avatar
Quoted: 5 Post(s)
I felt it was easiest, after years of removing smart body parts, to take off the whole front end (the front piece and two side fender panels) as a single unit. it was very easy. I also removed the 'hood' and the panel above the fresh air intake in order to access the top of each shock absorber. And the side rocker panels.
I found the that lower portion (the smallest diameter portion) each each spring was broken and was causing the crunching sound. The bottom of each spring was able to extend below the lower mount point on each shock.
post #3 of 10 (permalink) Old 07-13-2019, 05:11 PM Thread Starter
stuberman's Avatar
Quoted: 5 Post(s)
Additionally, the bellows that protect the shock absorber were split (4); the bearing (#7) was seized (it allows the shock and spring to turn easily); the 'spring insulators' were corroded or missing (6).
Parts 6 (two required an upper and a lower) & 7 were corroded or missing and needed to be replaced.
post #4 of 10 (permalink) Old 07-13-2019, 05:20 PM Thread Starter
stuberman's Avatar
Quoted: 5 Post(s)
So I ordered the following parts with a cost around $175
Bellows with KYB strut boots SB108 from Rock Auto $11.08 each side
Upper strut (spring) mounts with bearing REIN AVQ0481 from Rock Auto $11.21 each side
Lower spring insulators 451-322-01-84 from mbpartsexpress.com $6.72 each side
(this just sits on shock plate and spring is prevented from turning by a notch in the insulator)
Upper spring insulators 451-320-00-26 from mbpartsexpress.com $5.74 each side
(the old ones were totally rusted)
New Lesjofors front coil springs from ebay $94.89 /pair from qeautoparts1
These did fit but they took a while to figure out that they look different from the originals and have to be muscled into position.
The small object is the bearing and it sits inside the larger rubber spring mount. The rubber mount was fine but I could only find them as a pair.
The springs are from Sweden and both have what seems like a cut or notch near the top coil. Concerned that this could rust and break prematurely, I sprayed the notch (the size of a pencil tip) with rubberized undercoating. I also sprayed the insulators for good measure since they were the most corroded.
post #5 of 10 (permalink) Old 07-13-2019, 05:32 PM Thread Starter
stuberman's Avatar
Quoted: 5 Post(s)
Taking the old parts out:
I bought a nice air impact wrench for $39 from Harbor Freight and some impact sockets, including extension bars and swivel heads and spring compressor, since I knew the top nuts on the shocks were very hard to remove with any other tool (some others have welded bits onto the shock to keep the piston from turning). I found my shocks were still working fine and I did not want to replace them if I did not have to. Replacement shocks start around $50 each from Rock Auto. Tools needed cost about $130 if I don't include the impulse purchases like a mechanics cart, nice creeper, and other stuff that kept calling my name.
The top nut(s) came off easily with a 1/2" air impact wrench and then I removed the lower ball joint, stabilizer link and steering outer tie rod end.
Seeing that the front brake rotors looked bad, I decided to replace them with an upgrade kit from Rock Auto - POWER STOP K5695 Z23 Evolution Sport Brake Upgrade Kit with coated and slotted rotors and ceramic pads to reduce dust.
post #6 of 10 (permalink) Old 07-13-2019, 05:51 PM Thread Starter
stuberman's Avatar
Quoted: 5 Post(s)
I painted the rotors and calipers using a Dupli-Color BCP101 ($9 from Amazon) caliper paint that almost matched my car (again since 2008 - see my original post here: DIY - painting brake calipers and drums )
And shoved it all back in place:
First put lower insulator on shock; then fit small end of coil spring onto shock; then push wide end of bellows onto shock (the small stop is a complete pain to push over the threaded part of the shock absorber); use a spring compressor to compress the spring; then put the upper insulator, the bearing and rubber spring mount over the threaded portion of the shock and finally the nut that holds it all together. I won't tell you how hard it is to get the spring compressor disentangled if you don't grab the spring in the right place. Too close to the end and it gets stuck in the coils, too far away you can't compress the spring enough to get the nut back on. But it wouldn't be a fun vacation if I didn't have a puzzle to figure out.
Then, assuming the shock and spring assembly is together, just lift the upper end into the cavity above the wheel well and guide the lower ball joint into the steering knuckle. Fit the upper stop (a rubber coated mount) and the upper nut and the nut on the ball joint.
The install and tighten the nuts for the outer tie rod and stabilizer link. Reconnect the ABS cable.
Then I mounted the pretty new rotor, the caliper support and caliper.
Then put the front end back on along with side rockers (I also replaced on that was torn up badly.)
Finally the torque the tire and it should be done.
jwight and twcom like this.
The Following 2 Users Say Thank You to stuberman For This Useful Post:
jwight (07-14-2019), twcom (07-14-2019)
post #7 of 10 (permalink) Old 07-13-2019, 08:25 PM
Quoted: 8 Post(s)
WOW, bet it is much better now!!
duckhunter9090 is offline
post #8 of 10 (permalink) Old 07-14-2019, 07:54 AM
Bohemian Moderator 451gas
Quoted: 78 Post(s)
Thanks for the tutorial - it's a sticky now.
jwight is offline
post #9 of 10 (permalink) Old 07-14-2019, 04:55 PM
twcom's Avatar
Quoted: 99 Post(s)
I Have already got my front end off for radiator issues.......... hmmmmmm if money was no object..... Cant wait to hear the after driving review.
twcom is offline
post #10 of 10 (permalink) Old 07-15-2019, 06:54 AM Thread Starter
stuberman's Avatar
Quoted: 5 Post(s)
The car rides like a champ again. Turning is smoother and bumps seems to be less pronounced. Brakes were always good, but will be looking out for how dirty the front wheels get now, the OEM pads seem to create a mess within a week.
