Static/popping noise through speakers when key removed - Smart Car Forums
post #1 of 7 (permalink) Old 10-23-2013, 08:30 AM Thread Starter
Quoted: 1 Post(s)
Hello there,
Just bought a 2008 ForTwo -it had a flat battery so I replaced it and started the car for the first time. When I take the key out there is a static/popping sound coming from the speakers even though the radio is not on.
When I put the key in and switch the radio on the popping sound goes away.
I see here that others may have had a similar problem - does anyone know of a way of fixing this problem?
Please help - this is driving me mad!!
Thanks,
Kenny in Ireland
kennysmyth is offline
post #2 of 7 (permalink) Old 10-23-2013, 08:53 AM
BB Benz's Avatar
Quoted: 230 Post(s)
I think I remember the problem is in the head unit. Might be a great time to upgrade the radio.
Obviously the radio is not powering down the amp at least not fully anyway.
A radio shop might be able to repair it if you can find one. Probably easiest just to replace it. If that doesn't do it, you might have a loose ground somewhere.
BB Benz is offline
post #3 of 7 (permalink) Old 10-27-2013, 04:12 AM Thread Starter
Quoted: 1 Post(s)
Thanks m8, I will check the ground.
post #4 of 7 (permalink) Old 09-15-2015, 08:42 AM
I've got this problem too. Did you ever check your ground connection?
Scott216 is offline
post #5 of 7 (permalink) Old 09-15-2015, 10:34 AM
Quoted: 199 Post(s)
The radio can be powered for a short time without the car being 'on'. So there is a live power feed to the radio. I would think something with the head unit. Might be time to replace.
stevenjb is offline
post #6 of 7 (permalink) Old 09-15-2015, 11:43 AM
smark's Avatar
Quoted: 668 Post(s)
The radio can be turned on anytime without the key in the ignition. If the noise is minor. Might not want to worry about it.
smark is offline
post #7 of 7 (permalink) Old 06-21-2016, 07:08 AM
Cubby
I have the same problem. Found a used radio on ebay. No help. It may also be defective but I suspct the problem is elsewhere. Anybody found a solution?
Cubby70 is offline
interference , popping , radio
HELP~! Speakers popping noise . . . SubSlr88 smart General Discussion 8 09-15-2015 08:41 AM
gwyns (noisy speakers, popping) gwyns Audio & Video 6 02-06-2011 03:40 AM
Noise from Speakers Key Off GeoCar smart Operation and Maintenance 6 02-04-2011 10:46 PM
Key makes clicking noise when I turn it. purly smart Operation and Maintenance 0 01-17-2010 09:06 PM
Beeping noise after key is removed skyzdlimit59 smart Operation and Maintenance 2 05-13-2008 12:46 PM
