Strange stuff all of a suden. (radio, no reverse, ABS light) - Smart Car Forums
post #1 of 8 (permalink) Old 11-30-2011, 07:27 AM Thread Starter
I'm at 40k plus and have had no issues with my Smart, until now....
the other day my radio started switching into a mode I don't have; it would go into a Phone -navigation mode, the display would say Phone/Navi and I can't get any of the controls to work, the only way to fix it was to turn off the radio off then back on then it would switch modes again, turn it off and back on then it would switch again. Now it's fine, but a day or two after that I couldn't get the car to shift into reverse I had to play around with it for about 10 min hasn't done it again since (knock on wood), now this morning the triangle warning indicator came on and stayed on until I shut the car off and then started it again....
Not sure what is going on any one have any ideas, I'm going to schedule my serverce for next week, but I thought I would check and see if anyone has had this happen to them.
a1woodwrks is offline
post #2 of 8 (permalink) Old 11-30-2011, 07:33 AM
Bohemian Moderator 451gas
Quoted: 78 Post(s)
Radio issue has popped up at least once: https://www.smartcarofamerica.com/for...problem-34191/ No resolution.
As for the shifter and the triangle light, I'd check all the grounds in the cabin, make sure you have brake lights and check the battery voltage with the engine off. Just possibilities based on other threads.
jwight is offline
post #3 of 8 (permalink) Old 11-30-2011, 07:35 AM
Quoted: 6 Post(s)
+1 and check your battery too!
tablist180 is offline
post #4 of 8 (permalink) Old 11-30-2011, 09:06 AM
To the XCAPEPOD!
rfernatt's Avatar
Quoted: 68 Post(s)
Do you have anything plugged into the power outlet? We've seen some odd behavior caused by devices plugged in that disrupt communications on the car's onboard network. Checking the battery voltage and grounding points is also a good idea.
Otherwise, use a Scanguage to check for codes or stop by a local auto parts place and have them pull any codes that might be a clue to the problem.
rfernatt is offline
post #5 of 8 (permalink) Old 11-30-2011, 09:55 AM Thread Starter
Nothing plugged in I'm going to check the batterey voltage after i get back to the house this afternoon.
I have an appointment next week for the 40K service, so I'll see what they say.
post #6 of 8 (permalink) Old 11-30-2011, 09:56 AM
BB Benz's Avatar
Quoted: 230 Post(s)
The not going into reverse could be a separate and well known issue. You should get the 2.03 software update done on the transmission since you have had this problem at least once. We don't want you stranded somewhere or needing to back up from a RR crossing in a hurry and not be able to, that could hurt or worse! So getter dun! Getting that done won't hurt anything, if it should turn out to be something else.
BB Benz is offline
post #7 of 8 (permalink) Old 11-30-2011, 09:58 AM
Check your battery. If good, check your serpentine belt. If good, check your alternator.
Brand Manager Kamaal is offline
The Following User Says Thank You to Brand Manager Kamaal For This Useful Post:
jwight (11-30-2011)
post #8 of 8 (permalink) Old 11-30-2011, 05:12 PM
SmartDigger's Avatar
Quoted: 178 Post(s)
I say low power issue also. bad battery, ground, or alt.
SmartDigger is offline
ABS light is on Stella503 smart Operation and Maintenance 43 01-24-2011 08:27 PM
ABS Light on/off intermittently. cathybear smart Operation and Maintenance 1 06-06-2010 06:14 AM
ABS Light On rcexplorer smart Operation and Maintenance 30 05-14-2010 07:04 AM
ABS Warning light jimvw57 smart Operation and Maintenance 2 11-26-2008 06:50 AM
Strange fog light behavior dancote smart General Discussion 14 02-27-2008 05:25 PM
