Rear (window) washer - Smart Car Forums
 6Likes
post #1 of 46 (permalink) Old 03-08-2009, 01:10 PM Thread Starter
My rear window washer has stoped shooting out fluid.The front works fine and you can hear the pump working when you push for the rear but nothing comes out.Any ideas?
turk1949 is offline
post #2 of 46 (permalink) Old 03-08-2009, 01:13 PM
jefferios's Avatar
Quoted: 73 Post(s)
Hmm, not sure. If you were in a colder climate I could suspect freezing fluid in the hose, but since your in Florida no idea. A trip to the Smart Center is needed.
jefferios is offline
post #3 of 46 (permalink) Old 03-08-2009, 06:51 PM
BigWarpGuy's Avatar
Quoted: 112 Post(s)
Perhaps the line is broken or it might be clogged?
BigWarpGuy is offline
post #4 of 46 (permalink) Old 03-08-2009, 07:04 PM
Quoted: 212 Post(s)
...remove small rear panel on the left side...peel back sound deadener...small blue hose is attached with the wire bundle in that area...you may have to pull the white foam insulation bag...there's an electrical plug under some foam shield but the hose has a push in fitting next to it...ask me how I know..ok..just fixed mine today
jetfuel
jetfuel is offline
The Following 2 Users Say Thank You to jetfuel For This Useful Post:
Crzy4x4 (03-14-2016), starplot (05-19-2017)
post #5 of 46 (permalink) Old 03-08-2009, 07:18 PM
Mine stopped working about a month ago, in the same way as yours turk. Because it's not urgent I've been putting off a trip to the dealership until I can get the updates at the same time.
windscythe is offline
post #6 of 46 (permalink) Old 03-08-2009, 07:23 PM
Quoted: 212 Post(s)
windscythe...try this ..use the rear washer for a few seconds..step behind the car and see if you have washer fluid behind the left rear wheel...if you do...it came of the fitting plug...
jetfuel
jetfuel is offline
post #7 of 46 (permalink) Old 03-09-2009, 07:14 AM
Bohemian Moderator 451gas
Quoted: 78 Post(s)
jetfuel
Glad to hear you solved the problem. Did you get any photos of the hose and connector?
jwight is offline
LouisM (03-28-2012)
post #8 of 46 (permalink) Old 03-09-2009, 08:17 AM Thread Starter
turk1949
Thanks Jetfuel (etal),
This is a great sight, ya'll are always helpful.I'll see if I can find that panel (any photo's would help)and give it a try!
turk1949 is offline
post #9 of 46 (permalink) Old 03-09-2009, 10:25 AM
Quoted: 212 Post(s)
..no photos..my camera was at work..I'll shoot some this afternoon if you still want to see it...I relocated the plug/washer fitting for easy access next time...you can see it by just removing the side panel...
jetfuel
jetfuel is offline
post #10 of 46 (permalink) Old 03-09-2009, 10:40 AM
Jetfuel, I already had a friend check behind and under the car while I used the rear washer. I did that just after it started happening- no sign of anything leaking.
Rear window wiper!!! jimnkaran smart General Discussion 30 01-08-2017 02:30 PM
Rear window handle jediknight36 smart General Discussion 6 12-04-2008 09:48 AM
Rear Window Defogger Alan From New York smart General Discussion 0 11-22-2008 08:49 PM
Rear Window Advertising jimvw57 smart General Discussion 4 11-10-2008 03:19 PM
451 Cabrio rear window SmartCarGuyAZ smart fortwo (451 - US vehicle) 5 12-25-2007 08:49 AM
