How to hook up an iPod - Smart Car Forums
 1Likes
post #1 of 13 (permalink) Old 12-28-2011, 12:38 PM Thread Starter
HELP! I can't figure out how to hook up my iPod to my smart Car through the USB port...when I plug it in it just reads 'device unavailable' do I need a different cable?
EMaSmart is offline
post #2 of 13 (permalink) Old 12-28-2011, 01:18 PM
I'm assuming you have the entryline radio, 2011+ models only. The iPod is not directly compatible with the usb input. It will only charge through that port, and *some* versions of the iPod will play music in a file format that is not meant for a human to understand.
The best way is to use the 3.5mm port and control your iPod music from the iPod itself.
The usb input is designed for mp3 files installed on a thumb drive or other hard drive. In other words, all the music files you placed on your iPod should be copied onto usb thumb drives as mp3 files. You can create folders and have song lists and you will then be able to browse your music collection directly from your entryline radio.
Brand Manager Kamaal is offline
The Following 2 Users Say Thank You to Brand Manager Kamaal For This Useful Post:
b322da (12-28-2011), EMaSmart (12-28-2011)
post #3 of 13 (permalink) Old 12-28-2011, 03:09 PM
esteban's Avatar
This system works well for me. I plug a 32 bit ipod connector into the ipod and then the single pin into a headphone amplifier in my glovebox (http://howto.cnet.com/8301-11310_39-20031047-285/pump-up-your-ipods-sound-for-$60/). I put a small hole in the rear of the glovebox to access the amp. The amp then connects directly to the built in smart connection. The ipod itself is in the cavity to the right of the steering wheel and is constantly charged via a usb connection (also part of the 32 bit connector wiring) in my 12 volt access point in the middle of the car. The wires are all hidden and I love the sound.
esteban is offline
post #4 of 13 (permalink) Old 01-02-2012, 06:06 PM
Hermes's Avatar
Can I control the music on the radio if I am using the AUX input? or will I have to manually change things?
Hermes is offline
post #5 of 13 (permalink) Old 01-02-2012, 06:12 PM
If you're using AUX you can only control music from your iPod. If you want to control music files, you can use a thumb drive in the usb port. Trying to use the usb port to control your iPod will not work because the entryline radio is designed for mp3 files and not Apple AAC files. The closest you can get to organized control would be to organize folders with mp3 files on your flash drive, then you can cycle through all your playlists and songs from the entryline radio.
Some iPods work through the usb port, and you can control the iPod itself through the entryline radio. BUT, it was not designed for that and as such there will be literally NO organized way of finding the songs you want to play. It's complete random computer assigned filenames.
You can literally hand Stevie Wonder an iPod and he'll have an easier time finding songs and playlists on it than you will trying to find songs on your iPod directly from the entryline radio.
post #6 of 13 (permalink) Old 08-25-2014, 02:40 PM
TheKeeper's Avatar
Quoted: 4 Post(s)
My radio manual for my entry line radio in mt 2013 smart says that the usb only works with fat32 files which are what the Ipod touch is supposed to use am I missing something???
TheKeeper is offline
post #7 of 13 (permalink) Old 02-08-2018, 10:56 AM
Quoted: 2 Post(s)
I have the entryline radio (2011) and I have a similar problem. I cannot make the USB work. It always says "device unavailable" when a USB drive is plugged in. The user manual says it has to be formated in FAT32. I tried 3 USB drives (2GB, 16GB and 64GB) all formated in FAT32 (also tried formating them in NTFS, exFAT and FAT, with the same result). I also tried with my android phone. Same message appears when plugged in. "Device unavailable".
Smart suggested that I might have to place the mp3 files directly in the USB drive (no folders). I did that. Same thing.
I've tried an old 2GB iPod I had at home and it works.
Does anyone have any suggestion? Is there something I'm missing?
How do you guys make the USB drive work? What file system (format) do you have? How do you sort your mp3 files?
adriakus is offline
post #8 of 13 (permalink) Old 02-08-2018, 01:56 PM
Bohemian Moderator 451gas
Quoted: 78 Post(s)
Welcome to SCoA! I'm using a 32GB USB stick in a 2011 and it works fine. Not sure what the issue with your radio is if the drive is correctly formatted and the files are actual mp3 format. Maybe a car stereo shop can help you out...
Smart Bob likes this.
jwight is offline
post #9 of 13 (permalink) Old 02-08-2018, 06:54 PM
Mod ♥ 450/451/453 + Motos
Miss Mercedes's Avatar
Quoted: 166 Post(s)
The headunit has to be able to access the files you device youíre using. Because of this, phones are out of the question. iPhones and iPod Touch devices use a file system that the smartís headunit doesnít support and Androidís OS confuses the headunit so Android phones are not compatible either.
This leaves you with old iPods and USB flash drives formatted to FAT32. What are you using to format the drive? Mac or Windows?
Also make sure that these are mp3 files and that there arenít any weird folders that do not belong.
I also think the port in the car is a USB 2.0. Iím not sure what impact that has if your drive is 3.0. Technically you should be okay, but the headunit is kinda dumb, so Iím not sure.
Miss Mercedes is offline
post #10 of 13 (permalink) Old 02-09-2018, 07:14 AM
smark's Avatar
Quoted: 668 Post(s)
Just use your old iPod for your music. I had the same issue, with my other brand vehicle too. ďDevice unavailableĒ. Even when Iíve added mp3 music from my iMac/iTunes. Same with data files. Formatted stick not correct? It madding. I've plug it right back into the iMac. To see if the memory stick was bad. Device unavailable. Itís crazy.
New after market sound systems for the smart car. Are cheap now. Iíd personal would replace the smarts head unit, with a better new one. Crutchfield carries a wide range. Bluetooth, hand free calls, USB that works etc. I like Bluetooth steaming. Even though USB is better quality. But itís a smartcar sound system.
Just use the iPod. It was designed for music. I use one, in all my cars. Itís got to be over 10 years old now. Plus I have a draw full, of old iPhone, I use for music too, in my cars, and the sound systems at home.
Good Luck.
smark is offline
ipod , radio , usb
Need a tow hook Stretchmobile Original (450) smart fortwo 3 06-12-2011 03:53 PM
Tow Hook parts4smarts Vendor Deals 0 04-11-2009 07:05 AM
With hitch How do you hook up lights? SmartDigger smart Modifications 1 09-03-2008 07:39 PM
iPod Shuffle 1st gen hook-up?? Trubluesue Audio & Video 6 07-29-2008 07:33 AM
Help Me Plz!!!/audio Hook-up p1nball Audio & Video 10 07-05-2008 09:11 AM
