radio speaker questions - Smart Car Forums
 1Likes
  • 1 Post By ElementalDragon
post #1 of 5 (permalink) Old 08-26-2017, 01:30 AM Thread Starter
Quoted: 232 Post(s)
on an 08 Passion between the windshield and dash panel there is a black strip for the window defroster. at either end there is an area with holes, is that where the tweeter go? if so, how do you get that panel up to install the tweeters as i see no screws? also is the radio set up, wire wise, to install tweeters (and a subwoofer and/or rear speakers)?
TRobinson6 is offline
post #2 of 5 (permalink) Old 08-26-2017, 07:04 AM
Mod ♥ 450/451/453 + Motos
Miss Mercedes's Avatar
Quoted: 164 Post(s)
Yes those are where the tweeters went on pre-facelift 451s. To get to that place I imagine you'd have to deconstruct the dashboard a bit to get within reach.
https://www.evilution.co.uk/index.php?menu=ice&mod=632
Rear speakers weren't offered until the facelift (2011+) so no wiring for that, not sure about the tweeters or subwoofer though.
It'll probably be easier to add the door mounted tweeters of the facelift 451s or custom ones.
Miss Mercedes is online now
post #3 of 5 (permalink) Old 08-26-2017, 09:07 AM
Quoted: 52 Post(s)
Sounds like you found the right tweeter locations. No dash disassembly required. These spots are accessible from underneath the dash. The passenger side is fairly easy, but the driver's side is all by feel with one's arm trying to find a path through the mass of wires and cables.
The wiring is likely in place (my 2009 had it). The tweeter wiring connector is either clipped into a holder next to the tweeter mount or, as in my case, taped to another wire harness with what looks like masking tape.
Hope you're a contortionist!
~toaster
toaster is offline
The Following User Says Thank You to toaster For This Useful Post:
TRobinson6 (08-26-2017)
post #4 of 5 (permalink) Old 08-27-2017, 06:23 AM
Quoted: 199 Post(s)
From when I bumped around online looking at smart parts, those dash tweeters are hard to find and are expensive. Might be best to install aftermarket product, possibly integrated into the side door mirror sails.
Sent from Tapatalk on Android
stevenjb is offline
post #5 of 5 (permalink) Old 08-28-2017, 08:35 AM
Quoted: 289 Post(s)
Speaking from experience having owned a 2009 ForTwo Brabus Coupe with the upgraded speaker system including those tweeters and the underseat sub.... you're better off putting the tweeters on the A-pillar. I purchased a nice set of Hertz Audio component speakers for mine, and at first, had the shop put the tweeters in the factory location. HUGE mistake. The highs bouncing off the windshield just amplified them even more, which made the audio sound WAY too crisp. Took it back and asked if they could put them on the A-pillar, which they gladly did, and even they said it sounded much better.
If you're planning on trying to find the actual tweeters that came with the system, it shouldn't be too bad. If you're planning to buy some aftermarket ones, I'd say the factory location probably wouldn't be the best location.
TRobinson6 likes this.
ElementalDragon is offline
The Following 3 Users Say Thank You to ElementalDragon For This Useful Post:
fredp (08-29-2017), limoak (08-23-2018), TRobinson6 (11-08-2017)
Smart 2011 High Line Radio Speaker Upgrades Mylesend smart General Discussion 4 03-11-2011 01:40 PM
speaker questions david B Audio & Video 6 08-09-2009 10:29 AM
Does everyone use speaker level inputs on amps with Radio 10? jeffandpamsmith Audio & Video 10 06-23-2009 08:24 AM
Question concerning the quality of the radio/speaker output. Jeff C smart General Discussion 36 03-06-2009 08:11 AM
Hi everyone - radio & nav questions harleysmom New Members Area 15 03-31-2008 09:02 AM
