2014 Fortwo new owner advice - Page 3 - Smart Car Forums
 14Likes
post #21 of 24 (permalink) Old 06-20-2019, 12:03 AM
Quoted: 286 Post(s)
Originally Posted by DreamCarOwner View Post
It appears you have the factory size tires and wheels. The front is 155 and the rear is 175. The factory sticker for your tire pressures are 29 lbs in the front and 34 lbs in the rear.DCO
On my 2015 ED, the recommended tire pressures are 29 front, 36 rear for those same tire sizes. I found a good compromise at 32 front, 34 rear. I am running a 20 mm spacer behind the front wheels which softens the front suspension in compression and that probably allows me to run that much front tire pressure without losing my fillings, but I believe that a pressure differential closer to what I am running provides better turn-in and a bit more grip up front.
InjuredAgain is offline
post #22 of 24 (permalink) Old 06-20-2019, 01:29 PM
GASHOG's Avatar
Quoted: 3 Post(s)
Originally Posted by russell_314 View Post
The insulation on the mat that goes over the engine is cracked in two but it's not visible when it's down. Just something I'd consider replacing in the future.
Russell I think that the insulation mat on the engine cover is possibly under a recall and MB will replace that for free.
Recall Number 18V273000
Recall Date 04/27/2018
Component ENGINE AND ENGINE COOLING:ENGINE
GASHOG is offline
post #23 of 24 (permalink) Old 06-20-2019, 04:37 PM
Mod ♥ 450/451/453 + Motos
Miss Mercedes's Avatar
Quoted: 164 Post(s)
They're talking about the mat attached to the carpet in the trunk, not the engine mat.
russell_314 likes this.
Miss Mercedes is offline
post #24 of 24 (permalink) Old 06-20-2019, 04:54 PM
Quoted: 4 Post(s)
You want to stay as far away from Mercedes as possible. That is unless your independently wealthy.
Miss Mercedes and russell_314 like this.
beakyboy is offline
