Aftermarket radio install - Smart Car Forums
 4Likes
post #1 of 28 (permalink) Old 04-18-2018, 05:40 AM Thread Starter
jAndrew's Avatar
Quoted: 11 Post(s)
I've gained a lot of info here but still coming up short on the correct way to wire an aftermarket head unit in my 2015 Cabrio.
The unit is an Alpine iLX-007. Crutchfield suggested a Metra 70-1784 adapter for the unit, but I also read elsewhere from people that actually installed an aftermarket unit used a Metra 70-1783. I tried the 1783 but got nowhere. I will recheck everything and use a meter tonight as I was a bit rushed. Crutchfield advised to switch the yellow and red around as well. Evilution advises that should not be the case but 'some creative' alternatives might be required since there is no ACC position.
So for those who have actually done it- What to do about the ACC wire and what adapter was used. Hopefully you can help me to get this wrapped up.
On a side note, has anyone removed the front roof trim on a Cabrio? Evilution has a guide for a coupe, not a Cabrio. I've removed the visors and 4 bolts but cannot get the outside edges loose. I managed to stuff the cables (for a mic and dash cam) but would really like to do it better.
jAndrew is offline
post #2 of 28 (permalink) Old 04-18-2018, 05:48 AM
Quoted: 13 Post(s)
I removed the roof trim in my Cabrio. Remove the A Pillar trims to expose another screw at the corner of the trim panel. Once the screws are removed, you can pry down and disengage all of the snap clips for the panel. Once you release all the snap clips, the entire panel has to be pushed toward the front of the car to release. It has tabs across the front of the panel that hook into the windshield frame at a front to back direction. I discovered this the hard way when I broke 2 of the tabs
Sent from my iPhone using Tapatalk
tim_arkansas is offline
The Following User Says Thank You to tim_arkansas For This Useful Post:
jAndrew (04-18-2018)
post #3 of 28 (permalink) Old 04-18-2018, 06:10 AM Thread Starter
jAndrew's Avatar
Quoted: 11 Post(s)
Thanks for saving me from the same mistake. How do the a-pillars come off? I thought there was a screw in the top under the roof trim. I was afraid to pull on the A-pillar too much since it already deform a bit from manipulating it.
jAndrew is offline
post #4 of 28 (permalink) Old 04-18-2018, 06:33 AM
Quoted: 13 Post(s)
You are correct! Thanks for setting me straight. Itís been a while since I removed mine. The screw I was thinking about is the one hidden by the roof panel. I had it reversed! Ugh! That screw is the only screw that holds the A pillar trim in place. Once itís removed, the pillars are released by pulling toward the center of the car to release the tabs, then lift them out. The only screws for the roof trim are the 2 for the visors, and the one for the visor clip. Sorry for the misinformation!
post #5 of 28 (permalink) Old 04-18-2018, 07:13 AM
Niteshooter's Avatar
Quoted: 85 Post(s)
According to Metra's online parts guide the 70-1783 is the correct wiring adaptor. The part Crutchfield suggested is listed as 88-07 Aud. Plugs look identical however pin placement on the left side bank appear to be different. Metra Online | Parts | Metra Auto Parts Online Warehouse
I thought though that a radio swap required some sort of SAM reprogram but I might be thinking of something else so don't quote me on this.
Niteshooter is offline
post #6 of 28 (permalink) Old 04-18-2018, 01:27 PM Thread Starter
jAndrew's Avatar
Quoted: 11 Post(s)
I thought that was the case, thanks for the update. I still cannot get either of the outside corners loose to push forward, not sure what my issue is but I am using a lot of force and it is going no where.
jAndrew is offline
post #7 of 28 (permalink) Old 04-18-2018, 01:28 PM Thread Starter
jAndrew's Avatar
Quoted: 11 Post(s)
Thanks, I will give it another shot. Nothing from any of the posts or guides mention a reprogram. That really should not be required.
jAndrew is offline
post #8 of 28 (permalink) Old 04-18-2018, 03:03 PM
Quoted: 17 Post(s)
I'm installing a Joying android unit right now. I have the 1783 adapter. I'm still putting the bullet connectors on all the wires and subsequently it's still on my kitchen counter with a big hole in my dash. I should know more tonight after work or tomorrow morning
I have the 2015 ED btw
centralohcpl is offline
post #9 of 28 (permalink) Old 04-18-2018, 03:56 PM
DowneasTTer's Avatar
Quoted: 98 Post(s)
Check out my thread on the subject. here:https://www.smartcarofamerica.com/for...-007-a-147530/
Yes Crutchfield is right at least on a 15. Cross the yellow and red. Works great but check your connections.
DowneasTTer is offline
post #10 of 28 (permalink) Old 04-18-2018, 04:14 PM
Quoted: 17 Post(s)
Cross the red and yellow as in they both have to wire together on the radio side to the yellow on the car side ?
Aftermarket radio install kit for 2013?? Derekns74 smart General Discussion 21 10-30-2013 05:26 AM
Will This Aftermarket Tach Install Easily On My 451? Pleasure_Pirate smart Modifications 11 05-26-2013 04:06 PM
Self install aftermarket sub? I have factory sub under seat.. JKSmartie Audio & Video 3 06-23-2012 09:31 PM
Made an aftermarket radio install video :) MegaManSE Audio & Video 4 01-14-2012 05:33 PM
Aftermarket alarm install speedygraphixink smart Modifications 0 10-28-2009 02:47 PM
