Anyone ever get Code U1113 ??? - Smart Car Forums
 1Likes
  • 1 Post By vadsoom
post #1 of 9 (permalink) Old 09-13-2019, 02:12 PM Thread Starter
Quoted: 5 Post(s)
Hello
Did anyone get code U1113 The Terminal 15 Signal on the canbus is missing or faulty.
I googled it and cant find anything
Biggermens is offline
post #2 of 9 (permalink) Old 09-13-2019, 04:15 PM
Quoted: 27 Post(s)
Here's what others on the site have said:
https://www.google.com/search?as_q=C...pe=&as_rights=
mvaldes is offline
post #3 of 9 (permalink) Old 09-15-2019, 05:57 AM
Quoted: 43 Post(s)
My issue turned out to be the ABS pump itself.
vadsoom is offline
post #4 of 9 (permalink) Old 09-18-2019, 04:16 AM Thread Starter
Quoted: 5 Post(s)
Mine seam to be working fine, it dose funny things when i first take off to the front wheels, then i get a error
but the ABS brakes work when i stand on it
I am stumped with this one, i got a couple more codes with the steering angel sensor and yaw sensor
Did not find much on google
post #5 of 9 (permalink) Old 09-18-2019, 05:12 AM
Quoted: 43 Post(s)
My ABS worked too. The failure was some kind of fault in the circuitry. I also replaced the yaw sensor in pursuit of repair. Please note, replacing these parts will result in a trip to your Mercedes dealer to have the code updated using a Star machine, unless you have one laying about.
jwight likes this.
vadsoom is offline
post #6 of 9 (permalink) Old 09-21-2019, 07:10 PM Thread Starter
Quoted: 5 Post(s)
I will change the ABS pump and yaw sensor for fun, I have a hole over car for parts ;)
and it just happens i do have a programmer laying around ;-P hehehe
we will see what will happen,
post #7 of 9 (permalink) Old 09-21-2019, 07:28 PM
Quoted: 43 Post(s)
Where did you get the programmer? How much was it? Did it work to reset after the abs pump and yaw sensor were replaced?
vadsoom is offline
post #8 of 9 (permalink) Old 09-26-2019, 04:19 AM Thread Starter
Quoted: 5 Post(s)
I got it from Snap-on its the ModisUltra it was about 3500$ Canadian, I never had a chance to change the ABS pump yet, but i did use it to reset the air bags, calibrate the clutch actuator, relearn the transmission, I can see data from every sensor
It has a option to bleed the ABS, I am sure it will reset the ABS no problem
I will keep you posted, I also used a OCT and a Launch to reset air bags
post #9 of 9 (permalink) Old 10-08-2019, 02:55 PM Thread Starter
Quoted: 5 Post(s)
I fixed my problem
This is what i did
With the snap on scan tool, i notice that the angel of the steering sensor was very off, but it would only calibrate if it was out by 10 degrees or less
0 degrees was all the way to the right pretty much right lock, what i did was move the wheel to the left 9 degrees at a time, and calibrate
I had to do that around 40 times hehe took about 3 hours to do but now 0 degrees is straight ahead
I put on at less 700 Km on it since with no problems, only have one code left driver seat weight impossible
A$$ H#$% car is calling me fat hehehe
Thanks for everyone help
