Battery keeps going dead? - Smart Car Forums
 2Likes
post #1 of 17 (permalink) Old 03-12-2017, 06:53 AM Thread Starter
Quoted: 4 Post(s)
All,
I have a unique problem with my 2008 Pure Smart Car. When I park my car in my driveway the battery goes dead in 3 days.
• I have been through 2 new battery’s so it is not a bad battery.
• It has been in two shops that can find no problem, it does not go dead when they have the car, over 4 days each time?
What I have discovered is that when the car is parked in a level location the battery does not discharge? Park in my driveway with a slight upgrade and it is completely dead in 3 days. No horn or dash lights etc.
I have made no mods to the car
Any ideas as to what may be causing this problem or how to trouble shoot it would be appreciated.
kulak is offline
post #2 of 17 (permalink) Old 03-12-2017, 08:16 AM
Quoted: 789 Post(s)
do you have the rain sensor on the windshield? They have been known to wear down the battery as they are always checking for rain Make sure the auto rain sense is off
jimvw57 is offline
post #3 of 17 (permalink) Old 03-12-2017, 09:22 AM Thread Starter
Quoted: 4 Post(s)
No rain sensor, this car has no options, roll up windows, no alarm, no mods, just plain old pure model.
kulak is offline
post #4 of 17 (permalink) Old 03-12-2017, 09:55 AM
smark's Avatar
Quoted: 654 Post(s)
Alternator, not charging.
smark is offline
post #5 of 17 (permalink) Old 03-12-2017, 10:30 AM
Quoted: 789 Post(s)
I would try either parking in a different spot, or disconnect the battery and see if it still goes dead. Parking a car on a slight slope shouldn't make any difference to the electrical system. I have always parked my cars on the street with a downhill slope and never experienced them going dead even after 3 weeks time. (2008 pure, 2009 passion)
jimvw57 is offline
post #6 of 17 (permalink) Old 03-12-2017, 10:46 AM
Rustedwrench's Avatar
Quoted: 224 Post(s)
Originally Posted by kulak View Post
All,
The battery draining only when parked on an incline seems implausible. The charging system would need to be tested for excessive a/c ripple on the dc output. If that tests good then a parasitic draw test would need to be done to narrow down the area of the fault. In either case the fault would have to be present for the tests to be meaningful.
Or the battery has a hole in it and the electrons are leaking out.
Rustedwrench is offline
post #7 of 17 (permalink) Old 03-12-2017, 11:48 AM
Mister_smart_LA's Avatar
Quoted: 627 Post(s)
Parasitic draw for real. I'd check for the most common issues that can cause a strong draw and quickly drain a battery. Headlamps, headlamp switch, brake lamps, anti-theft systems if applicable, suspect (although not very likely) the shift actuator, and definitely check the SAM unit while the vehicle is off. Do you have an upgraded aftermarket sound system, perhaps with amp or sub? If so, be highly suspicious about its install.
How long have you owned the car? If not original owner, dig under dash looking for an aftermarket alarm system that wasn't fully disconnected.
Mister_smart_LA is offline
post #8 of 17 (permalink) Old 03-12-2017, 12:29 PM
smark's Avatar
Quoted: 654 Post(s)
Human error
You’ve probably done this at least once in your life – you come home from work, tired and not really thinking, and left the headlights on or didn't completely close the trunk. Overnight the battery drains, and in the morning your car won’t start. Many new cars alert you if you’ve left your lights on, but may not have alerts for other components.
Parasitic drain
Parasitic drain is due to components in your vehicle continuing to run after the key is turned off. Some parasitic drain is normal – your battery delivers enough energy to keep things, like your clock, radio presets, and security alarm operational at all times. However, if there's an electrical problem, parasitic drain can exceed what's normal and deplete the battery.
Bad charging
If your charging system isn’t working properly, your car battery can drain even while you’re driving. Many cars power their lights, radio, and other systems from the alternator, which can make the battery drain worse if there's a charging problem. Then you’ll be stranded at roadside with a stalled car that needs a boost. And even then, bad charging will drain your car’s battery. A professional mechanic will be able to diagnose what's causing a charging problem.
Defective alternator diode
A car alternator recharges the battery and powers certain electrical systems. If your alternator has a bad diode, your battery can drain. The bad diode can cause the circuit to charge even when the engine is shut off, and you end up in the morning with a car that won’t start.
Old battery
If your battery is old, it might not hold a full charge. If your car consistently won't start, it’s possible that the battery is worn out. You should generally replace your car battery every 4-5 years. If your car isn’t starting consistently, and your battery is old, battery replacement should be the first thing you consider.
Having a battery that won't hold a charge is frustrating, and figuring out what's causing the problem can be tricky. Assuming that the cause of the battery drain is not human error, you will need the assistance of a qualified mechanic who can diagnose your car's electrical problems and determine if it is the battery or something else in the electrical system.
smark is offline
post #9 of 17 (permalink) Old 03-12-2017, 01:10 PM
Quoted: 789 Post(s)
All,
The car is a Pure, no auto lights or wipers, also says no additional equipment, 2 new batteries, I find it hard to believe that it would only happen in the spot you park it at home and not sitting at repair shop for 4 days. something is different.
To start with, check the battery voltage when it is running, then after you shut it off. After a few days check it again. There has to be something being left on or running when you park it. Maybe the door locks, or the dome light from a door that is not adjusted and parking on a slope causes the light to stay on? pretty far stretch, but then so is replacing the battery twice if there was nothing wrong with them. seems like something is missing here.
jimvw57 is offline
post #10 of 17 (permalink) Old 03-12-2017, 02:02 PM
Quoted: 209 Post(s)
I'd start looking into the ground connections at the battery and the ones near the engine. Then look at the positive connections to the starter and alternator.
jwight and Smart Bob like this.
kheran is offline
Dead Battery jordman New Members Area 38 08-26-2013 08:11 AM
dead battery bnapier smart Operation and Maintenance 3 02-01-2010 05:31 PM
Am I the only one with a dead battery? WilyB smart fortwo (451 - US vehicle) 41 11-11-2009 03:52 PM
Dead Battery (incl. battery charging) cablvr smart Operation and Maintenance 82 05-03-2009 08:18 PM
My battery is dead ............ Duckhunter The Car Lounge 3 01-29-2009 03:21 AM
