I haven't seen this mentioned before - heated seat problem. - Smart Car Forums
 1Likes
  • 1 Post By Rustedwrench
post #1 of 10 (permalink) Old 04-30-2014, 05:28 PM Thread Starter
He's not mine
NCC1701's Avatar
Quoted: 381 Post(s)
I think this is a first. Wanna know what y'all think about it.
Today upon starting the car at lunch time, I noticed the driver's side heated seat was powered up on low. It's always been Off on startup, regardless of what I had it on when I shut the car off.
After work, started the car and the same was true ... driver's side on low.
I played with it and found that instead of a three way toggle (Off, Low, High), I now have two ... Low, High, High.
Bad switch? Thoughts?
This is going to be undesirable soon with Summer heat on the way. I haven't checked yet to see if they're on their own fuse. Pulling the fuse would then be at least a temporary solution.
NCC1701 is offline
post #2 of 10 (permalink) Old 04-30-2014, 05:46 PM
Bohemian Moderator 451gas
Quoted: 78 Post(s)
First take is it's the switch but hard to say without a diagnosis. Any codes?
BTW, any flooding where you are?
jwight is offline
post #3 of 10 (permalink) Old 04-30-2014, 05:51 PM Thread Starter
He's not mine
NCC1701's Avatar
Quoted: 381 Post(s)
No codes. But, now that you mention it ... yes, we've had substantial rains. And, last night I forgot to close the passenger side window completely (doh). It was down perhaps 2 inches and the passenger side got some water. Not flooded, but dampened.
Hmmm.
Odd that the problem is on the driver's side if that's the cause though.
NCC1701 is offline
post #4 of 10 (permalink) Old 04-30-2014, 05:55 PM
Quoted: 78 Post(s)
Was wondering about general flood damage after watching the news tonight; didn't see that as causing the seat problem.
jwight is offline
post #5 of 10 (permalink) Old 04-30-2014, 05:58 PM Thread Starter
He's not mine
NCC1701's Avatar
Quoted: 381 Post(s)
That would be a different thread. As for your question, nothing major. It rains, streets flood. We're used to it.
EDIT at 0430: Catching network news ... I see why the concern. Funny how media makes things seem so much worse than it is on the scene. I am 100 miles from Pensacola. But, even when the national coverage is on the local area, they do tend to make things seem worse than the average Joe would tag them to be.
NCC1701 is offline
post #6 of 10 (permalink) Old 04-30-2014, 06:31 PM
SmartDigger's Avatar
Quoted: 178 Post(s)
The switches are impulse switches( they send a signal to the sam to turn them on,no current runs though them like a light switch.) I would try the disconnect the battery trick first.
SmartDigger is offline
post #7 of 10 (permalink) Old 04-30-2014, 06:52 PM Thread Starter
He's not mine
NCC1701's Avatar
Quoted: 381 Post(s)
I'll try that this weekend Digger. Thanks. Hope that will solve it.
I'll follow up.
NCC1701 is offline
post #8 of 10 (permalink) Old 05-01-2014, 04:51 AM
Quoted: 250 Post(s)
Originally Posted by SmartDigger View Post
?..no current runs though them like a light switch.
Not quite correct for home wiring. May or may not be correct for auto wiring. Light switches for home wiring break the positive feed. Touch that and ground yourself and you will find there is current running through the switch. You might not live to tell about it, though! =:-(
OliverB is offline
post #9 of 10 (permalink) Old 05-01-2014, 12:29 PM
Rustedwrench's Avatar
Quoted: 224 Post(s)
The seat heater switch is just an input to the heated seat control module, which in turn supplies current to the seat heating elements. So the question is whether the fault lies with the switch or the module. You can unplug the switch group and see if anything changes, or you can unplug the heated seat control module. The heated seat control module looks like an oversized relay that is next to the steering column under the dash above the accelerator pedal. If no result, you can disconnect the plug for the heater under the driver's seat. It should be a two pin plug with RED/BLU and BRN wires.
SmartDigger likes this.
Rustedwrench is offline
The Following 3 Users Say Thank You to Rustedwrench For This Useful Post:
chieftmc (05-01-2014), jwight (05-01-2014), NCC1701 (05-01-2014)
post #10 of 10 (permalink) Old 05-01-2014, 04:08 PM Thread Starter
He's not mine
NCC1701's Avatar
Quoted: 381 Post(s)
<scratching head>
Well, today the problem seems to have rectified itself. Go figure.
Good information provided and I appreciate it. If it should raise its head again I'll know what to try. Thanks!
NCC1701 is offline
2010 Facelift if you haven't seen it already. Evilution smart General Discussion 33 07-11-2010 04:46 PM
Smart Car Mentioned in AlterNet Article Krootie smart General Discussion 4 09-30-2009 03:16 PM
Audio problem from passenger seat shop hermit smart General Discussion 7 09-22-2009 07:26 PM
Problem with Driver Seat Adjustment MoSmart New Members Area 3 03-20-2009 11:38 AM
Haven't received Brabus Confirmation email yet.. John17 smart General Discussion 6 11-15-2008 08:10 PM
