Misfire - Smart Car Forums
post #1 of 10 (permalink) Old 02-06-2013, 04:19 PM Thread Starter
Misfire
mistyguchie here i had a problem with my smart-----misfire number 3 cylinder i changed gas , added heet, changed plugs, changed ignition coil wqs fine until 35 miles later then misfire again
2008 120000 miles other info see other post could it bre bad plugs?????
misfire prior to changes
mistyguchie is offline
post #2 of 10 (permalink) Old 02-06-2013, 04:26 PM
wahi's Avatar
Quoted: 18 Post(s)
Unclear whether you had the misfire first, and then did all the changes, OR... you had a misfire, did those changes and after 35 miles, the code came up again.
wahi is offline
post #3 of 10 (permalink) Old 02-06-2013, 04:38 PM
BB Benz's Avatar
Quoted: 230 Post(s)
The fact that you had an improvement, would lead one to believe you were having an affect in the right area. Did you try swapping injectors around?
BB Benz is offline
post #4 of 10 (permalink) Old 02-06-2013, 05:02 PM
Bohemian Moderator 451gas
Quoted: 78 Post(s)
120K miles - amazing nothing else is wrong at this point. Did you get any OBD codes? Compression check on the cylinders (nice to know info but might tell you something...) If it's only #3 is the wiring to that coil pack OK?
jwight is offline
post #5 of 10 (permalink) Old 02-06-2013, 09:24 PM
Brabus007's Avatar
Quoted: 90 Post(s)
He may have that valve thing going on...<:-((
Brabus007 is offline
post #6 of 10 (permalink) Old 02-07-2013, 05:09 AM
WhiteNBlack08's Avatar
Quoted: 360 Post(s)
A bad plug is possible, but unlikely with todays quality controls. Truth is, the misfire may have never went away. Are you diagnosing the misfire by a CEL code that the computer shows? If so, after a reset, there is usually a minimum number of times the fault has to occur before it trips the CEL. It may have taken 35 miles for that to happen. Unless it is a serious, or fatal fault, it won't trip the first time.
First thing I would do, is go to your local auto parts store and buy a quart of Marvel Mystery oil. Add 4 oz to every tank of gas until it's gone and see if it improves. You may have some carbon buildup on the valves, and that can cause a misfire. The MMO will help clean and lube the top of your engine, and possibly stop a $$$ repair.
I use the stuff regularly, and will pass 122K this next week. Good luck
WhiteNBlack08 is offline
The Following 3 Users Say Thank You to WhiteNBlack08 For This Useful Post:
BB Benz (02-07-2013), jefferios (02-08-2013), wahi (02-07-2013)
post #7 of 10 (permalink) Old 02-07-2013, 04:44 PM Thread Starter
mistyguchie misfire
thanks ill try it as soon as we get over this storm in the northeast====mistyguchie
The Following User Says Thank You to mistyguchie For This Useful Post:
BB Benz (02-09-2013)
post #8 of 10 (permalink) Old 02-09-2013, 03:18 AM
BB Benz's Avatar
Quoted: 230 Post(s)
Misty, you are going to have to keep us posted.
BB Benz is offline
post #9 of 10 (permalink) Old 10-30-2018, 11:18 PM
Quoted: 1 Post(s)
Swap injectors, coil packs and spark leads from #3 to a different cylinder. If the fault moves then you can narrow it down from there. If moving those does nothing it gets a bit more complex and I'd recommend a leak down test next to rule out mechanical failure (valves, gasket, rings etc)
junosi is offline
post #10 of 10 (permalink) Old 10-31-2018, 04:31 AM
Jo e Lefors's Avatar
Quoted: 203 Post(s)
Junosi sorry you responded to a dead thread from 2013.
Unable to find anyone to work on the smart, " mistyguchie " traded in her smart back in April of 2014.
Take care
JL
Jo e Lefors is offline
Generic P0303 engine misfire msmurphree smart Operation and Maintenance 73 02-18-2018 10:14 PM
Mitsubishi engine code #2 misfire greenek1 smart Operation and Maintenance 53 07-09-2016 05:16 AM
Code P0301 #1 misfire pack smart smart Operation and Maintenance 31 07-22-2012 11:21 PM
