FAQ: Rear Camera Install - Smart Car Forums
 1Likes
post #1 of 20 (permalink) Old 06-19-2018, 10:06 AM Thread Starter
Quoted: 6 Post(s)
Rear Camera Install
Hello All:
I have a Garmin GPS with the optional rear camera. It mounts on the license plate upper screws.
My question, has anyone wired a rear camera yet? If so, how did the wiring go? I know I have to get to the wiring and I figured the drivers side would be the easiest. Does anyone have the color code for the tail light assembly?
We have a rear camera on the other car in the family, and if adjusted correctly, quite handy.
Thanks in advance for any help.
Ned C:
in WISCONSIN.
NedleyC is offline
post #2 of 20 (permalink) Old 06-19-2018, 01:11 PM
Mister_smart_LA's Avatar
Quoted: 627 Post(s)
Originally Posted by NedleyC View Post
Hello All:
Ned C:
in WISCONSIN.
Tap into the power line going to the reverse light. It'll trigger the rear camera to turn on.
Mister_smart_LA is offline
post #3 of 20 (permalink) Old 06-19-2018, 01:21 PM
Quoted: 74 Post(s)
Yellow wire with Red stripe= Backup light
Optimist is offline
The Following User Says Thank You to Optimist For This Useful Post:
NedleyC (06-19-2018)
post #4 of 20 (permalink) Old 06-19-2018, 01:57 PM Thread Starter
Quoted: 6 Post(s)
Many Thanks !!
I can now finish my project...
NedleyC is offline
post #5 of 20 (permalink) Old 06-19-2018, 07:25 PM
Quoted: 13 Post(s)
I installed a camera as well. When the top is folded down in the last position it is impossible to see behind me. As others have already said itís a straightforward install. I wanted mine to look as OEM as possible, so I used a wire loom going from the tailgate into the car using the same grommet the license plate lighting wires go through. My 451 did not come with the optional dash pod gauges, so I purchased a lcd display for the camera and mounted it where the pods would go. I can upload photos if interested.
The monitor I installed as a 2nd video input, and Iíve debated on using an android tablet with video output linked to my OBD II adapter and connected to that input. With the proper triggers programmed when the car is running the torque app would display on the screen with various gauges and when in reverse the display would switch to the camera. As I said, Iíve debated...havenít done it yet. I ran across a YouTube video of a guy in Australia who used an old android phone as a permanent gauge display in his BMW. It frees up having to launch the torque app on his phone when he gets in the car...or in my case the OBDII adapters arenít compatible with my iPhone.
Sent from my iPhone using Tapatalk
tim_arkansas is offline
post #6 of 20 (permalink) Old 06-21-2018, 10:53 AM Thread Starter
Quoted: 6 Post(s)
update
Many thanks for your help Optimist. I will now finish my project.
Hey all: Just finished with the camera install. It's a BC 30 from Garmin. I fished the power leads on the drivers side down to the rear light area. Drilled a small hole in the surrounding metal for ground lead, and thanks to Optimist, tapped into the reverse light lead. Mounted the camera inside in the rear wiper plastic with a nut and small screw. and sure is nice to not have to give yourself whip lash to make sure nothing is behind.
Again, this project inspired me to spend the $15.00 to join.. I can't say enough thanks for the help with this.
Ned C:
jwight likes this.
Last edited by NedleyC; 06-21-2018 at 10:57 AM. Reason: Miss spelled a couple words OPPS
NedleyC is offline
post #7 of 20 (permalink) Old 06-21-2018, 06:53 PM
Quoted: 278 Post(s)
I thought about putting my backup camera i installed in my 453 there.... in the plastic lip above the rear wiper on the exterior.... but figured running the wires, even IF i could figure out how to easily take that piece off, would have probably been a bit of a nightmare. So i just took the rear panel off the tailgate (which wasn't very easy, either) and put it in the typical spot... above the license plate. Though, it made me wish i had bought a different backup camera, as this one is angled a bit too far towards the ground, so i see mostly the street behind me, and not as much as i'd like directly behind and off to the sides.
ElementalDragon is offline
post #8 of 20 (permalink) Old 06-22-2018, 12:12 AM
wheelandtirecare's Avatar
Quoted: 2 Post(s)
I think its not easy to install rear camera.
wheelandtirecare is offline
post #9 of 20 (permalink) Old 06-22-2018, 04:43 AM
jAndrew's Avatar
Quoted: 11 Post(s)
Ned C:
There is also a handy ground on the right side that is used foe the lights. You'll see it just to the right of the engine cover.
jAndrew is offline
post #10 of 20 (permalink) Old 06-22-2018, 11:36 AM
Quoted: 1 Post(s)
It is simple after cartoys quoted me 200 usd for install. I had it done myself in 35 minutes. Used the ground next to engine case and routed the wires from door panel under molding following existing wires.
Palleyne is offline
How To Install Backup Camera in a 2016/2017 Smart 453 WedWabbit Audio & Video 0 12-20-2017 06:54 PM
How about a rear-view camera for the Smart? Bremer Speck smart General Discussion 62 05-31-2014 11:13 AM
Advice for reverse camera and component install smartkiwi Original (450) smart fortwo 12 05-27-2012 11:12 AM
Front camera install grizzledcamudgen Audio & Video 10 04-05-2011 03:18 AM
