Rough idle and misfire codes - Smart Car Forums
 9Likes
post #1 of 21 (permalink) Old 04-09-2019, 08:02 PM Thread Starter
Quoted: 107 Post(s)
2011 with 89,000 miles idles rough and has all misfire codes P0300-P0303 stored, although the CEL isn't on. Will check/change the spark plugs first off. Then the valve adjustment. Anything else to check?
atikovi is offline
post #2 of 21 (permalink) Old 04-10-2019, 04:07 AM
Bohemian Moderator 451gas
Quoted: 78 Post(s)
Compression/leak down check. That sounds like a bad valve.....
jwight is offline
post #3 of 21 (permalink) Old 04-10-2019, 09:23 AM
Quoted: 804 Post(s)
I would give the Marvel Mystery Oil a try but it could be a bad valve...
Smart Bob likes this.
jimvw57 is online now
post #4 of 21 (permalink) Old 04-10-2019, 02:13 PM Thread Starter
Quoted: 107 Post(s)
Why would a bad valve only show itself at idle? It's smooth at other times.
atikovi is offline
post #5 of 21 (permalink) Old 04-10-2019, 10:56 PM
Quoted: 804 Post(s)
could be damaged hose or maybe a leaking intake gasket?? Without doing a leakdown test, we can only guess at the cause of the problem. Burnt valve has come up before.
post #6 of 21 (permalink) Old 04-11-2019, 04:49 AM
Quoted: 24 Post(s)
Is it missing at idle or just it just shimmy and shake a little at idle cause these little 3 bangers aren’t balanced very well. Do you have a steady beat coming from the tailpipe at idle? Do you hear a clunk we you go from reverse to drive it may be a worn out engine mount
Goofybutsane is offline
post #7 of 21 (permalink) Old 04-11-2019, 04:52 AM
1stiski's Avatar
Quoted: 102 Post(s)
Yeah . I agree .
1stiski is offline
post #8 of 21 (permalink) Old 04-14-2019, 08:30 AM Thread Starter
Quoted: 107 Post(s)
Yesterday the missing got worse. Went for a drive and 2 miles out the the CEL was flashing and the car had no power. Barely made it back. Did some checking today and found none of the coils had a mounting bolt. They were just sitting there loose in the hole. Found some bolts to secure them down. Idle is still rough but at least it's driveable. Did see #2 coil wire harness was hacked. Will drive it a little and see if all or just #2 misfire codes come back now.
wahi likes this.
atikovi is offline
post #9 of 21 (permalink) Old 04-14-2019, 11:22 AM
smark's Avatar
Quoted: 666 Post(s)
Did you check out any of your coil packs? Pulled any codes. How about, a bad, or dirty fuel injector. Sounds, like your cars, now gone into its limp mode.
smark is offline
post #10 of 21 (permalink) Old 04-14-2019, 03:41 PM
Mod ♥ 450/451/453 + Motos
Miss Mercedes's Avatar
Quoted: 164 Post(s)
Yup. Flashing CEL is the engine shutting down a cylinder or more. First thing first, I'd say check those plugs and coils.
Miss Mercedes is offline
Issue with rough idle and stalling laurasp smart General Discussion 8 04-19-2019 02:25 PM
Rough Idle and Running mbiskie smart Operation and Maintenance 12 01-25-2016 12:44 PM
Idle goes up and down (Idle surging) 16.luca Turbo 1 09-20-2014 12:14 PM
Very ROUGH Startup / Idle / Warmup bigcritter smart Operation and Maintenance 6 05-31-2008 04:33 PM
Rough idle blackbeagle smart Operation and Maintenance 9 04-18-2008 03:05 PM
