spark plug socket came loose from extension - Smart Car Forums
 2Likes
post #1 of 11 (permalink) Old 11-23-2016, 12:55 PM Thread Starter
Quoted: 26 Post(s)
and I can't retrieve it from the spark plug well. I am out of ideas and need help. The extension won't lock on the socket firmly enough to extract it and I can't get the plug out.
Any ideas are greatly appreciated
Charlie
cruisemon is offline
post #2 of 11 (permalink) Old 11-23-2016, 01:14 PM
Smart Bob's Avatar
Quoted: 174 Post(s)
I would try & grab the socket with needle nose vice grips. If the spark plug won't come out, it is probably cross threaded.I wouldn't try to remove it has the threads may be damaged. Hope you are not trying to r/r the plugs on a hot engine? I use an extra long spark plug socket that extends beyond the top of the cam/valve cover.
Smart Bob is offline
post #3 of 11 (permalink) Old 11-23-2016, 01:15 PM
Quoted: 789 Post(s)
find a strong magnet, or a pair of long nosed pliers with a long reach and grab the edge of the socket , or press the tips in the drive hole and open them up. Or if you have a piece of hose large enough to fit over the outside of the socket, you might be able to push it on and lift the socket up. ...
Just some ideas. I have a heavy duty magnet mounted on a spring for rescuing sockets and extensions that have fallen where they are not supposed to, has saved me a few times.
Next time a bit of electrical tape to secure the socket to the extension wouldn't hurt. I usually take the insert out of the socket, and always start the plug with a length of rubber hose. that way it won't turn hard enough to cross thread without the hose twisting. (when putting new plugs in)
jimvw57 is offline
post #4 of 11 (permalink) Old 11-23-2016, 01:34 PM Thread Starter
Quoted: 26 Post(s)
tried these ideas and it is too deep. I put a spot of fast cure epoxy on the end of an extension and put that down on top of the socket. We'll see in about 5 minutes if it worked
Charlie
post #5 of 11 (permalink) Old 11-23-2016, 05:09 PM
valvestem's Avatar
Quoted: 34 Post(s)
If that did not work, take a metal coat hanger rod about a foot long, take a needle nose plier and make a small "j" in the end of the metal hanger rod, small enough to fit in the socket drive opening, hook the j under the opening and pull it out. Note if a foot of hanger rod is not long enough, make it long enough to suit the depth
valvestem is offline
post #6 of 11 (permalink) Old 11-23-2016, 08:07 PM
Quoted: 789 Post(s)
The rear opening for the cover is also in the way I bet.
How about taking some thinner wire and make a spring coil about 6 inches long and make it a smaller diameter than the socket, then push it over the socket and turn it so it threads down past the lower end of the socket. it might get small enough on the lower end to be able to pull it up from the bottom ??
maybe take an extension and grind down the end so the retaining ball sits lower in the socket, but not low enough to fall out. Might work but will most assuredly wreck the extension
Just throwing out ideas here..
jimvw57 is offline
post #7 of 11 (permalink) Old 11-24-2016, 12:13 AM
Mister_smart_LA's Avatar
Quoted: 627 Post(s)
Charlie
Will your extension secure enough so you can rotate the spark plug out? If the plug is loosened enough I would believe it should come out with the plug socket. The rubber boot in the plug socket is likely gumming up the works just enough to have mildly seized the plug socket to the plug. I would try a different assortment of extensions until one of them is just snug enough, and if that doesn't work I would use needle nose pliers to pick at the plug socket. Try lightly rotating in both directions, the opposite way, so you can also slightly undo any cross threading you may have done between the plug socket and the plug. Something will work. Keep trying.
Mister_smart_LA is offline
post #8 of 11 (permalink) Old 11-24-2016, 07:07 AM
Quoted: 212 Post(s)
...lift the car until the wheel clears the ground...this will increase the allowable space you have to work with....
Jetfuel...BTDTFT....
Smart Bob likes this.
jetfuel is offline
post #9 of 11 (permalink) Old 11-24-2016, 07:17 AM
SmartDigger's Avatar
Quoted: 178 Post(s)
Magnetic retriever for screws and such
SmartDigger is offline
post #10 of 11 (permalink) Old 11-24-2016, 09:25 AM
Quoted: 52 Post(s)
A locking extension such as this would have prevented the problem in the first place.
Sears.com
It may still be possible to insert one of these into the socket and slip a screwdriver down alongside it and slide the lock button.
~toaster
toaster is offline
Found Loose Factory Harness with plug left of dash kirame Interior & Exterior 3 02-14-2017 02:23 PM
Can't get to Spark Plug #1 rigacci smart Operation and Maintenance 11 07-11-2016 10:46 AM
Flat plug extension cable? Schorschi smart fortwo Electric Drive 8 07-26-2014 10:02 AM
What size spark plug socket? konsole smart General Discussion 10 01-06-2013 03:00 PM
New Hazet Spark Plug Socket For Sale sykes05 Dealers and Parts 0 11-18-2011 03:26 AM
