sway bar bushing - Smart Car Forums
 1Likes
  • 1 Post By shop hermit
post #1 of 2 (permalink) Old 08-26-2018, 12:51 PM Thread Starter
Quoted: 17 Post(s)
sway bar bushing
There have been several posts over the years about front-end noises (thumping/rattling) that were dignosed as worn bushings in the sway-bar. I have have had a rattling noise in my 08 for a long time...noticable mostly at slow speeds on bumpy pavement. Before getting a pair of the newer bushings that are supposed to be made from a different material, I thought I would split the old ones and add a shim made of copper flashing material behind them to see if that was definately the curplit. Didn't help a bit. What it really sounds like is slack in the rubber bushings at the top of the shock in the struts. I tried to tighten them, but couldn't budge them. Put some penetrating oil on them, but still couuldn't get them to budge. Has anyone replaced their struts or tightened them and if so, how did you get the nuts to break loose? A little heat would undoubtedly help, but I am reluctant because of the rubber (?) bushings and plastics nearby. Putting a lot of torque on them is difficult because of the cramped quarters. I guess removing the front clip may be the answer, but I'm saving that as a last resort.
Jebcidic likes this.
shop hermit is offline
post #2 of 2 (permalink) Old 09-01-2018, 09:41 AM
Quoted: 3 Post(s)
You might want to check your end links for play in the top mounting bracket on the strut. Mine were periodically working themselves loose and causing rattles. I even replaced the stock end links with some moogs and they started to rattle after a couple of months. I then ended up putting some blue lock tight on and haven't had an issue for 7 months. Before I was re-torquing them every few months.
kjp4756 is offline
MDH model starter/alternator bushing replacement video rubyg smart Operation and Maintenance 0 10-25-2013 06:53 AM
Where can I get an aftermarket Sway Bar for a 451 PINOYPOWERS smart Modifications 2 03-30-2011 04:34 PM
Front sway bar preload? VinceLA smart Operation and Maintenance 13 06-16-2010 10:41 AM
Anti-sway bar!!?? SWIFTY smart General Discussion 19 06-28-2009 08:15 PM
Sway Bar for the Smart SmartPassion smart Modifications 1 06-30-2008 06:41 PM
