How-do Lucky,
Here's my experience on my 2016. And it just happen in less than week. Last Friday I took the squirrel over to the local grease-balls up my way to have my new snow tires installed. On the way over the TPMS kicks on, I pulled over to check my tires and they looked ok so I reset it. It worked but then came on again, so I figured one tire was below or maybe multiple tires were below the preset pressure.
They installed my tires and said their equipment would not recognize my sensors. At which point I told them not to worry about it as I had to program it myself by the dash reset.
So I did and it worked. I wanted to take my new rubber out for a spin to see how they felt and sure enough it came back on. Only this time I get a message saying no sensors are installed.
But since I'm a student of following things to the T I start investigating and discover through Mercedes literature and find out there is a possibility I have radio interference with the electronics in the TPMS through my aux plug in the radio 3.5 jack.
Ok now we are talking my language cause now we are going to do a reset by the book.
#1 I unplug that jack
#2 I wait over 24 hrs for the tire pressure to be truly cold
#3 I get out my air gauge and mini compressor and fill all tires to correct spec.s (I added 1 1/2 lbs to compensate for cold air loss as I'm semi-mountain region and old man winter is just about here about 1 lb loss for every 10 degree drop)
#4 I then get in the car and start the engine, but did not drive it. I reset it and waited over 2 minutes before I shut it off. This morning I took the squirrel on an extended trip (144 miles round trip) to get a better feel for the new tires and wala it's all working good again.
I was never in a real panic about it because I knew the sensors where there and they were not malfunctioning in the realm that they had gone bad. But I will admit some of the screen messages it will give you can cause alarm.
Do it by the book before you let them bums con you into new sensors. As far your fuse goes even if I knew I would not tell you. Get you GoggleFu on.
Good luck to ya and may the force be with you.
____________
1st Note: I was using that jack to plug my phone into to listen to my music files through the on-board speakers as we cannot get radio reception where I live
2nd Note: The Smarts are one of the few cars today were we can activate any new TPMS installed or reinstalled after a tire change without the need to go to the dealer to have it done or the tire shops that's why his equipment could not recognize it and why the computer said they were not installed
