Valve cover gasket trick? Rtv? - Smart Car Forums
 3Likes
  • 1 Post By toaster
  • 2 Post By atikovi
post #1 of 4 (permalink) Old 05-22-2019, 01:27 AM Thread Starter
Working on our newly acquired 12 Smart the valve cover was previously I stalked with grey RTV and leaking badly, I order a gasket and it came today. I figured it would have a lip & bolt holes. But it’s just a thin silicone bead material. And the grove on the valve cover is very shallow. What’s the trick to get it to stay in place as I install it? I have worked on several cars mostly Euro cars, and this is a first running into this type of gasket without a placement grove or through bolt holes. What’s everyone doing? Thanks
Joejoe is offline
post #2 of 4 (permalink) Old 05-23-2019, 06:33 PM
Quoted: 52 Post(s)
Try using a thin coating of Hylomar Universal Blue. It will give you a bit of a tacky surface to stick the gasket in place. It doesn't set like an RTV does.
I use it all the time as a coating on the paper gaskets common on motorcycles. Because it doesn't set, I can remove and reuse the gaskets.
It used to be available through NAPA and Permatex, not sure if they are still licensed to produce/sell it. Otherwise Amazon looks to have it.
Hylomar Universal Blue Sealant - PL32
~toaster
Jo e Lefors likes this.
toaster is offline
The Following 2 Users Say Thank You to toaster For This Useful Post:
Jo e Lefors (05-24-2019), Smart Bob (05-24-2019)
post #3 of 4 (permalink) Old 05-24-2019, 06:56 AM
Quoted: 107 Post(s)
I just put some RTV in the groove, then the gasket and wait 20-30 minutes until it's semi-cured before installing.
And might as well replace the spark plug tube seals if they weren't before.
DreamCarOwner and Jo e Lefors like this.
atikovi is offline
The Following User Says Thank You to atikovi For This Useful Post:
post #4 of 4 (permalink) Old 05-24-2019, 07:09 AM Thread Starter
Thanks for the input. I’m going to try the gasket dressing today. And yes I got new plugs, and have been dong as many preventive things as possible. Removed & cleaned and re-lubed the shift actuator and gear selector motor. And have been going over any paint or corrosion while I have it apart.
Joejoe is offline
Bad Gas ?? Head Gasket ?? (PCV valve) groundloop smart General Discussion 81 11-30-2015 02:29 PM
Oil pan - gasket or RTV? briansmart Modifications and Repairs 14 06-26-2013 11:18 AM
Leaky valve cover gasket. Leonardo smart Operation and Maintenance 4 02-22-2013 06:03 PM
Broken Valve Stem Gasket chihuahuak94me smart General Discussion 5 01-07-2011 04:52 PM
Jibjab smart trick (or trick smart) SmartPassion smart Videos 9 04-01-2008 05:49 AM
