Flat tow on a budget... - Page 3 - Smart Car Forums
 6Likes
post #21 of 27 (permalink) Old 06-11-2017, 08:27 PM Thread Starter
SmartieAZ's Avatar
Quoted: 5 Post(s)
My bungee cord is 34 inches...
There where already two holes at the seat frame - I just put 2 key rings in for the bungee hooks!
Name:	Smart towbar 11.jpg
ID:	31561   Click image for larger version
Name:	Smart towbar 12.jpg
ID:	31569   Click image for larger version
Name:	Smart towbar 13.jpg
SmartieAZ is offline
post #22 of 27 (permalink) Old 09-24-2017, 06:13 PM Thread Starter
SmartieAZ's Avatar
Quoted: 5 Post(s)
Just came back from 3000 miles flat towing my smart - everything worked out great, expect I lost after 700 miles the front hood... good that someone recommended to
tape it down and I didn't do it. The plastic closing things just disintegrated and so the hood opened.
I installed some metal hood closing pins...
Name:	Smart Colgan front bra 02.jpg
ID:	34425   Click image for larger version
Name:	Smart Colgan front bra 01.jpg
post #23 of 27 (permalink) Old 09-24-2017, 09:46 PM
Quoted: 6 Post(s)
could you please post a picture of how you mounted the pins
Lowell is offline
post #24 of 27 (permalink) Old 09-25-2017, 07:00 AM
slomarsh's Avatar
Quoted: 10 Post(s)
Wow, you found everything you need at a discount. Good deal!
I purchased the Roadmaster baseplate and Falcon 2 from E trailer. Installed myself. Not for the faint of heart- took 2 days working only a few hours each day.
Hardest part? removing and re-installing the side sills (rocker panels) All just to remove one body clip fastener on each side hidden under the sill!!
Installed a battery cut off. Owner's manual says to do so on our 2014 model. Also, I bypassed the smart wiring and installed aftermarket LED lights wired directly to the RV. Only $18 for the pair from Walmart. Wiring harness was on $7 from Walmart. I made brackets from Home Depot by bending mending plates 90 degrees. They mount and remove in seconds. I'll take a pic and post. Finally, while the front body clip was off I ran the wiring through the lower grill so as to avoid the problem of the front access panel (hood) from coming loose or me forgetting to fasten it correctly each time.
chieftmc likes this.
slomarsh is offline
post #25 of 27 (permalink) Old 09-25-2017, 06:45 PM
Quoted: 84 Post(s)
Looking forward to your pics
chieftmc is offline
post #26 of 27 (permalink) Old 09-26-2017, 07:46 AM
Niteshooter's Avatar
Quoted: 85 Post(s)
We had to Macgyver some OEM tow hooks in order to move my smart to a safer location the other day until it can be fixed. Recycled the tow bar from my Jeep CJ.
I don't recommend this for a long term solution though it's interesting that folks in Europe mount their tow bars to the stock tow hook bolt holes. On my smart we had to drill a hole on one side as it did not have a hole in the plastic cover but has the threaded bolt hole hiding behind.
Got some spikes to cover the holes when not in use though I have since ground off the tips to make them 'safe'.
ID:	34505   Click image for larger version
ID:	34513   Click image for larger version
Smart Bob likes this.
Niteshooter is offline
post #27 of 27 (permalink) Old 09-26-2017, 11:27 AM
slomarsh's Avatar
Quoted: 10 Post(s)
I posted a new thread with pictures. ( Hope I did it right)
slomarsh
slomarsh is offline
flat tow , smart , smart 451
Flat Tow ?? YES!!! apowers smart Towing 365 10-23-2017 02:03 PM
Experience: Flat tow or trailer tow? airstreamtoad smart Towing 0 03-11-2015 09:57 AM
Flat tow voids warranty? jwight smart Towing 14 01-08-2014 05:16 AM
smart car flat tow jrmsoldier69 smart General Discussion 4 09-05-2010 06:59 AM
Sprinter Flat Tow? Fenwick smart Towing 9 10-30-2009 08:59 PM
