HOW-TO: Step by Step Curt/Uhaul Hitch Install (LOT OF PICS!)l - Page 3 - Smart Car Forums
 5Likes
post #21 of 49 (permalink) Old 04-24-2012, 02:33 PM
OTD3 lifetime Member
Quoted: 41 Post(s)
Jim did not actually take the lower panel off, he just loosened one end and moved it out of the way.
Great job on the pictures and how to.
jkjahobbs is offline
The Following 2 Users Say Thank You to jkjahobbs For This Useful Post:
chieftmc (06-22-2013), Kermit (06-20-2013)
post #22 of 49 (permalink) Old 06-20-2013, 01:41 PM
Quoted: 41 Post(s)
We used your instructions today as my son put a hitch on my Bumblebee. It was his first time to do any work on a smart. He's calling it The pregnant Bumblebee.
I've named my smart Sunshine.
The Following 4 Users Say Thank You to jkjahobbs For This Useful Post:
a2jack (06-21-2013), chieftmc (06-22-2013), 10632 (06-20-2013), Kermit (06-20-2013)
post #23 of 49 (permalink) Old 06-21-2013, 08:04 PM
cpear451's Avatar
Quoted: 5 Post(s)
Curt Hitch AND Borla Exhaust?
I'm waiting to see if anyone tries to fit both the Borla exhaust with the Curt hitch. (or similar system if there's a cheaper alternative)
http://www.borla.com/products/fortwo...t__140299.html
BigWarpGuy likes this.
cpear451 is offline
The Following User Says Thank You to cpear451 For This Useful Post:
BigWarpGuy (06-15-2014)
post #24 of 49 (permalink) Old 09-20-2013, 04:12 PM
Installed the wrong thing first?
I already installed the hitch, but now I want to install my Boesch center exhaust. Any chance I can fiddle the exhaust above the hitch without uninstalling the hitch?
stevnjessie1 is offline
post #25 of 49 (permalink) Old 09-21-2013, 07:58 PM Thread Starter
Lifetime Member
Kermit's Avatar
Quoted: 6 Post(s)
I've done it before. It can be done. It has been a while and I did have the car on a lift.
Kermit is offline
The Following User Says Thank You to Kermit For This Useful Post:
stevnjessie1 (09-22-2013)
post #26 of 49 (permalink) Old 09-22-2013, 10:18 AM
You're right, it was a peice of cake. Many Thanks
post #27 of 49 (permalink) Old 06-14-2014, 10:35 AM
Quoted: 13 Post(s)
Thanks, Kermit! You made my life a lot easier today when I installed my hitch. Here are pictures of the parts that come with the hitch. First, the bolts, nuts and the spacers that go inside the frame rails to hold the bolts:
And here are the spacers that go between the hitch and the frame, the fish wires and the washers that are used when reinstalling the serpentine belt cover:
Next up is wiring up the flat 4 trailer connector - but that has to wait until Amazon gets the rest of my order here.
-Bob
Kermit and Miss Mercedes like this.
RDMaysJr is offline
The Following 2 Users Say Thank You to RDMaysJr For This Useful Post:
Kermit (06-14-2014), Miss Mercedes (06-16-2014)
post #28 of 49 (permalink) Old 06-15-2014, 05:26 PM Thread Starter
Lifetime Member
Kermit's Avatar
Quoted: 6 Post(s)
You're welcome and thanks for adding pics of the items I forgot to add pics of.
Miss Mercedes and jkjahobbs like this.
Kermit is offline
post #29 of 49 (permalink) Old 06-15-2014, 10:15 PM
BB Benz's Avatar
Quoted: 230 Post(s)
The no grind method is far easier to do once you understand that by sliding the inner bumper left to fish the bolts thru on the right side and then sliding it to the right to fish bolts for the left side, grinding is no longer necessary. One does still have to drill the missing hole for the middle bolt on the right side.
It is not necessary to temporarily mount the hitch, mark the center hole for the right side, remove the hitch and drill the hole. Simply mount the hitch drill through the hitch hole thru the frame. You are now ready to start using the fish wires to place the bolts.
It is important to remember that the hitch and or bike rake now mounted behind the Brabus or other center mount exhaust will become heated the longer the engine is running. One could be burned. The locking pins on my Swagman bike rack do get hot, even though I do not travel long distances with it. The longer you travel, the hotter and more likely burns could happen. Just keep it in mind.
So far, I'm really impressed with the Swagman/Curt combination. Mounting and dismounting the bikes from the bike rack could not be easier. I did add two tow bolt adapters that allow me to easily secure two turnbuckles to prevent twisting and sway of the bike rack.
The two ratchets that clamp the bikes in place eliminate all straps. Great and fast improvement over my previous rack with all it's straps and knots. The ratchets even have a hole for a lock to lock the bikes to the rack.
BB Benz is offline
post #30 of 49 (permalink) Old 06-16-2014, 05:50 AM
Quoted: 279 Post(s)
What do you guys do to corrosion-proof the newly drilled holes? Are you not worried they will eventually rust out?
SuperSmartie is offline
DIY Step by Step Speaker Installation (door) cubefx Technical "stickies" 37 10-09-2017 05:12 AM
Smart 451 (H7) H.I.D Installation- Step by Step instructions with pictures braddman smart Modifications 154 10-11-2015 05:00 PM
Curt Hitch ??? sheureka smart Towing 34 06-26-2010 07:44 AM
Yea! I have taken the First step opas momma New Members Area 3 07-14-2008 05:14 PM
Step inside Green New Members Area 0 08-16-2007 10:09 PM
