453 Coolant - Smart Car Forums
 2Likes
  • 2 Post By jetfuel
post #1 of 10 (permalink) Old 12-25-2018, 11:52 PM Thread Starter
Quoted: 86 Post(s)
453 Coolant
What store brand coolant works well for the 453 model?
(First change interval is 60,000 miles or six years).
White Lightning is offline
post #2 of 10 (permalink) Old 12-28-2018, 06:53 PM Thread Starter
Quoted: 86 Post(s)
The 451 model has an interval of 40,000 miles/4 years to replace the coolant. The 453 coolant interval is 60,000 miles/6 years. Considerable difference.
The 451 uses MB BeVo 325.0 (which only applies to cars manufactured until April 2014). https://bevo.mercedes-benz.com/bevolisten/325.0_en.html
The 453 manual (p. 210) cites MB BeVo 310.1 https://bevo.mercedes-benz.com/bevolisten/310.1_en.html
No coolant brands listed.
At the bottom of p. 210, it says "smart recommends an antifreeze/corrosion inhibitor concentrate in accordance with MB Specifications for Operating Fluids 310.1 or 325.6" The products for 325.6 are European and not easily available in the USA. https://bevo.mercedes-benz.com/bevolisten/325.6_en.html
Suggestions? Thank you.
post #3 of 10 (permalink) Old 12-28-2018, 09:20 PM
OTD3 lifetime Member
Quoted: 41 Post(s)
Following.
jkjahobbs is offline
post #4 of 10 (permalink) Old 12-28-2018, 09:42 PM
Quoted: 213 Post(s)
...why not test the coolant and see if it really needs replacing...
Jetfuel...easy..tester..strips or voltmeter...
jwight and Mister_smart_LA like this.
jetfuel is offline
post #5 of 10 (permalink) Old 12-29-2018, 04:32 AM
Bohemian Moderator 451gas
Quoted: 78 Post(s)
Going out on a limb here but I'm guessing the same coolant that worked for the 451 would be OK for the 453 gasser. I'm also confused by the "which only applies to cars manufactured until April 2014" wording. Since the 451 carried on here for the 2015 model year I don't think the change applies to our final model year 451s. YMMV.
jwight is offline
post #6 of 10 (permalink) Old 01-03-2019, 07:28 PM
Quoted: 70 Post(s)
I used Xerex G-05...
It’s a HOAT, hybrid organic.
Look at NAPA...
https://www.valvoline.com/our-produc...freeze-coolant
mattwithcats is offline
post #7 of 10 (permalink) Old 01-04-2019, 01:30 PM
Quoted: 52 Post(s)
The required coolant is likely used in other Mercedes models. When I changed the coolant in my 2009 451 I went to the local (non-smart) Mercedes dealership and got a gallon of 325.0 factory spec coolant concentrate. Beats trying to determine if the aftermarket stuff is correct and the price was very reasonable at $23.50.
~toaster
P.S. Did you see this note?
3. Mixing Ratio
3.1. Sheets 326.x
The products listed in the Specifications for Operating Fluids 326.x are coolants or finished mixtures and must not be mixed with water. When using them, compliance with the concentration (50/50) must be ensured in addition to the MB approval (see item 5).
toaster is offline
post #8 of 10 (permalink) Old 04-16-2019, 01:50 PM Thread Starter
Quoted: 86 Post(s)
In this thread, I should've used the term "antifreeze" instead of "coolant."
I called the service center to order 325.0 MB antifreeze for my 453. The representative looked it up and said that 325.0 is not for the 453 model. I'm going to wait until the next time I can go in person to see what the MB antifreeze for the 453 smart car is.
post #9 of 10 (permalink) Old 04-26-2019, 05:52 AM Thread Starter
Quoted: 86 Post(s)
Specification 310.1 for smart car 453 model says to use fluids from 320.1
On 320.1: https://bevo.mercedes-benz.com/bevolisten/320.1_en.html
On the chart look for the smart car engine smart model 453: (M281)
**see the footnote2 for M281. Says it's NOT compatible with products on 325.0
post #10 of 10 (permalink) Old 04-26-2019, 09:22 PM
Mailman's Avatar
Quoted: 23 Post(s)
Check the color (really!) of the existing coolant.
450-451 used 'blue' Pentosin, like the Volvo R and many VWs.
453's started coming with 'pink' Pentosin; that would be only 2016 and 2017 in NA.
Like Toyota only wants you to use Toyota RED
Mailman is offline
2016 453 throws CEL ( coolant bypass valve) PDXsmart smart Operation and Maintenance 4 10-11-2017 10:28 AM
coolant for 453 Paul Va Technical "stickies" 0 11-12-2016 04:06 PM
Coolant Leak - Lost coolant tank cap boxster233 smart Operation and Maintenance 14 04-13-2016 02:36 PM
Coolant levels? JD10367 smart General Discussion 5 12-27-2008 08:24 AM
Oil Temp and Coolant Temp Gauge Install VinceLA smart Modifications 22 07-23-2008 08:00 AM
