Fuel gauge - Smart Car Forums
post #1 of 8 (permalink) Old 10-29-2018, 09:34 AM Thread Starter
Ron Burgess's Avatar
Fuel gauge
Fuel gauge on my 2016 had been stuck on FULL through several fill-ups and it had been very slow at excepting fuel from pump. Now I have appointment to bring car in for service and now gauge working properly and excepting fuel at pump at normal flow....Question: should I cancel appointment and hope problem doesn't occur again or waste my time and money and have them look at it?
Ron Burgess is offline
post #2 of 8 (permalink) Old 10-29-2018, 10:41 AM
Quoted: 2 Post(s)
Fuel Gauge Concerns:
I would cancel if the gauge is now working. They won't repair unless they can verify a malfunction.
Bob Ricewasser is offline
post #3 of 8 (permalink) Old 10-29-2018, 06:58 PM
Quoted: 34 Post(s)
Look around the forum, this has been discussed ad nauseam.
The cure (under warranty w/less than 50K mi) is to have the dealer replace the fuel tank/sender.
S u b R o s a
SubRosa is offline
post #4 of 8 (permalink) Old 10-29-2018, 08:29 PM
Quoted: 289 Post(s)
S u b R o s a
well... technically, the issue requiring replacement of the fuel tank was the fact that basically since launch, people hadn't been able to put CLOSE to the specified 8.7 gallons into the tank. Don't remember any of that having to do with a fuel gauge that won't go down, and issues pumping gas INTO the tank.
ElementalDragon is offline
post #5 of 8 (permalink) Old 10-29-2018, 08:50 PM
Quoted: 34 Post(s)
It is all related. Our '16 did as yours, slow fueling and the gage stayed at 'F' for half the tank.
The new tank fills easily over 8 Gallons and the gage, while still not linear, reads accurately towards the end where it is most important.
SR
SubRosa is offline
The Following User Says Thank You to SubRosa For This Useful Post:
Bob Ricewasser (10-30-2018)
post #6 of 8 (permalink) Old 11-10-2018, 05:11 AM
ShoshTrvls's Avatar
Quoted: 57 Post(s)
I just started having this same problem. Gauge stayed full to over 150 miles; has dropped 2 bars at 177. That’s usually when I’m down to one or two bars left. Interestingly, this started after I had let the tank get below .5 gallons before a fill up so I wonder if that screwed with the sensor in some way. (And to the person who said it’s “all over the forum” this is a completely different problem. I had all the “fix” work done for the fuel tank problem well over a year ago (not that it really solved the issue completely)).
ShoshTrvls is offline
post #7 of 8 (permalink) Old 12-16-2018, 12:43 PM
Quoted: 289 Post(s)
Bit of a bump here.... but just to clarify to SubRosa....
The only issue i've ever had with my 2016 in regards to the gas tank has been the amount I am capable of putting into it. I never had an issue with it not wanting to accept fuel as fast as a fuel pump can dish it out, nor has mine ever remained at full for longer than it should have and then quickly plummeted from there. Like i said, I had my fuel tank replaced quite a while ago, and i'm still unable to pump anywhere near the quoted 8.7 gallons into the tank.
Just the other day, I was low on gas, and figured I could still make it home from work. Well, i did, but just barely (maybe?). So I figured what a perfect opportunity to show just that. As you can see in the first picture, my fuel gauge was showing 0.0 gallons remaining. As you can see in the second picture, I put 6.9 gallons into the tank. That was after pumping at full speed for about half the amount, then slightly less than half speed for the rest. I, of course, bumped it up a few cents just to get an even total.... but still. The '09 i had i could get it to 8.7 gallons like clockwork every single time, and could easily calculate my actual MPG from tank to tank. This one, because of this, I have no idea if i'm getting the ~45mpg that i've been figuring, or if it's higher or lower than that. I'm tempted to try it with the dealer again.... see if they could look into it one more time, but I doubt they would seeing as they've already replaced the tank under the same trouble code.
post #8 of 8 (permalink) Old 12-16-2018, 04:43 PM
Mod ♥ 450/451/453 + Motos
Miss Mercedes's Avatar
Quoted: 164 Post(s)
So I've been told there is an actual fix for the fuel tank as of early this year. Unsurprisingly smart USA nor the dealers bothered to notify anyone.
Miss Mercedes is offline
Fuel gauge game! (gauge issue)? MarcfzSmartCar smart Fuel Economy 20 05-31-2014 11:30 AM
Fuel Gauge Stuck On Full redbluff smart Operation and Maintenance 14 09-07-2012 08:25 AM
How to Video: Installing the BMS Scan Gauge Bracket and Scan Gauge SmartMadness smart Videos 2 08-28-2010 10:47 AM
Fuel Gauge problem smarish smart Operation and Maintenance 3 06-20-2008 05:37 AM
fuel gauge reading t-bone smart Operation and Maintenance 10 02-11-2008 03:52 PM
