Replacing the activated charcoal filter (cabin filter) - Smart Car Forums
 8Likes
  • 4 Post By Mister_smart_LA
  • 4 Post By hossbuilder
post #1 of 5 (permalink) Old 10-25-2016, 05:48 PM Thread Starter
Quoted: 10 Post(s)
Has anyone replaced the cabin filter on their 453? After paying the dealer an absurd amount to do it as part of the 10,000 mile/Service A maintenance, I checked to see if I could do it myself. I see where the filter goes, but it seems like access to it is blocked by the accelerator pedal. Is there a trick to removing/installing the filter?
ZacMatic is offline
post #2 of 5 (permalink) Old 10-25-2016, 08:23 PM
Mister_smart_LA's Avatar
Quoted: 627 Post(s)
It's easy to do yourself, just a little door next to the gas pedal. The filter itself makes up the bulk of the cost, not so much the labor charge IMO. The aftermarket ones are probably 1/2 to 2/3rds less dense in filtration material, so you will get what you pay for... the oem one is so much more effective...
Mister_smart_LA is offline
post #3 of 5 (permalink) Old 04-15-2017, 11:00 AM
Quoted: 3 Post(s)
I have a 2016, 453. there are two things you should know. After quite a bit of research, I learned two important things. If you look at the uTube videos on line, they show you the filter comes out the driver's side of the center console. While the latchable door is still there, you cannot get the filter out as the throttle (gas pedal) assembly is in the way. Rather, you remove the floor mat and the panel underneath it that holds the flat tire kit. Then you can access the latchable door on the passenger side of the center console and pull the filter out.
The second thing I learned is that Advance Discount Auto sells an excellent replacement cabin air filter for under $9.00. It has charcoal and is constructed better than the OEM Mann filter the car comes with. It is a perfect fit. The Advance Auto part number is 90223C.
Neil
citroen, OliverB, Pinan and 1 others like this.
hossbuilder is offline
The Following 6 Users Say Thank You to hossbuilder For This Useful Post:
citroen (04-16-2017), Niteshooter (09-24-2017), schtdygirl (05-23-2017), Smart Bob (04-15-2017), Team_Smartcar (08-09-2018), ZacMatic (04-16-2017)
post #4 of 5 (permalink) Old 04-15-2017, 11:23 AM
Quoted: 249 Post(s)
Thanks! About ready to do the cabin filter in my 453.
OliverB is offline
post #5 of 5 (permalink) Old 09-23-2017, 11:39 PM Thread Starter
Quoted: 10 Post(s)
I bought a new OEM Mann filter from the dealer (photo attached), and when searching for the Mann part number, I found this handy PDF that contains removal instructions that are easier to reference than scrubbing through a video:
https://catalog.mann-filter.com/medi...g/HBgn6O60.pdf
ZacMatic is offline
The Following User Says Thank You to ZacMatic For This Useful Post:
jwight (09-24-2017)
Changing cabin air (activated charcoal) filter Ron F smart Operation and Maintenance 44 09-19-2016 09:27 AM
Cabin Filter, $12.77!!!! injunwiz Deals & steals 11 05-10-2013 05:29 PM
Cabin filter every 10,000 ? konsole smart General Discussion 12 11-15-2012 04:31 PM
Cabin filter from J.C. Whitney. micmou smart Operation and Maintenance 17 11-08-2012 12:28 PM
Cabin air filter CorkyF smart Operation and Maintenance 9 02-05-2012 04:38 PM
