453 LED headlight bulb options - Smart Car Forums
 3Likes
  • 1 Post By Huronlad
  • 1 Post By Miss Mercedes
  • 1 Post By Ferragamo4me
post #1 of 10 (permalink) Old 09-16-2017, 10:17 AM Thread Starter
elmosisu's Avatar
Quoted: 16 Post(s)
Hello smart people. Our new 453 has stock headlight bulbs and I'm looking for LED drop in replacement bulbs that work with the CANBUS system and also fit with little or no modification. I did a search here, and I didn't have any luck finding anything Thanks in advance
elmosisu is offline
post #2 of 10 (permalink) Old 09-16-2017, 11:07 AM
Huronlad is offline
post #3 of 10 (permalink) Old 09-16-2017, 11:40 AM
Mod ♥ 450/451/453 + Motos
Miss Mercedes's Avatar
Quoted: 164 Post(s)
My 453 has working LED headlights. To get them to work I had to modify the grommets to allow venting the fans.
I don't drive the car in the rain so I can't say for moisture, but the lights look great!
I'll have to pull the car out of the garage, take some pics, and make a thread.
The lights I used were Auxbeam H4 8000lm LEDs from Amazon. I modified the grommets by drilling a giant hole to them and screwing a medium sized medicine bottle into the grommets. This extra space allows some breathing room. I then drilled a small hole into the bottom of the medicine bottle for venting.
Mister_smart_LA likes this.
Miss Mercedes is offline
post #4 of 10 (permalink) Old 09-16-2017, 11:55 AM
Ferragamo4me's Avatar
Quoted: 43 Post(s)
H4 HB2 9003 G7 Hi/Lo 6500K Philips Lumileds ZES LED Headlight Conversion Kit | eBay, installed these about 6 months ago,they look incredible,also put LED's for fog lights too
FiveSpeed likes this.
Ferragamo4me is offline
The Following User Says Thank You to Ferragamo4me For This Useful Post:
NW453 (01-30-2019)
post #5 of 10 (permalink) Old 09-16-2017, 02:28 PM Thread Starter
elmosisu's Avatar
Quoted: 16 Post(s)
They look great! So the kit went in for the headlights with no modifications? Any CANBUS issues?
elmosisu is offline
post #6 of 10 (permalink) Old 09-16-2017, 02:30 PM
Quoted: 43 Post(s)
Had no issues at all
post #7 of 10 (permalink) Old 09-16-2017, 02:33 PM Thread Starter
elmosisu's Avatar
Quoted: 16 Post(s)
Thanks for the note. I live in the Pacific Northwest were rain is our middle name
Hoping to find an option where there is no risk of moisture problems
elmosisu is offline
post #8 of 10 (permalink) Old 09-16-2017, 03:00 PM
lebikerboy's Avatar
Quoted: 73 Post(s)
These are without any doubt the best alternative for a 453. However you would have to modify
the rubber cover with a hole as MM suggested to accommodate the longer rear portion and to
thread on the heat sinks. Also, not sure the front portion of the bulb will fit in the space allotted...
H4 Philips LED Headlight Review | H4 LED kit Review | 12953BWX2
lebikerboy is offline
post #9 of 10 (permalink) Old 09-23-2017, 03:37 PM
lebikerboy's Avatar
Quoted: 73 Post(s)
I stand corrected...
Sorry for the large font, don't know why.
Anyway, these lights are fantastic, they
are extremely well made and also allow
you to change the length of the bulb
portion (not necessary) and shorten
the heat sink distance (necessary).
They colour matches the led DRL exactly.
Price is excellent. This is what should come
as standard when the LED package is ordered.
post #10 of 10 (permalink) Old 02-24-2019, 05:48 AM
tikkin's Avatar
I installed the hikari Phillips version https://www.amazon.com/gp/aw/d/B077B...?ie=UTF8&psc=1
The bulb fitted fine but had to make a slight cut at the bottom of the cover to run the wire out for the ballast. Cut it slightly offset so the wires give the bulb a bit of torque tension to keep the bulb straight and locked in.
So far no moisture issues gone thru many rainy days and high pressure car washes. No heating issues so far either but haven't gone thru real heated summer yet. I'm not to happy with the beam pattern tho, here are some pictures.Attachment 41396
tikkin is offline
Headlight bulb replacement - what I always forget PerryA smart Operation and Maintenance 7 01-02-2016 04:42 AM
Changing headlight bulb JoanR Canada Chapter 4 11-30-2013 08:47 AM
Blown headlight bulb update jwight smart Operation and Maintenance 35 01-02-2013 08:45 AM
Headlight bulb upgrade Quagmire smart General Discussion 22 12-09-2010 08:30 PM
Left headlight out. Bulb is ok and fuse is ok, now what? crepatas smart Operation and Maintenance 1 02-01-2010 04:30 PM
