cdi engine swap into Roadster?? - Page 2 - Smart Car Forums
post #11 of 16 (permalink) Old 01-12-2013, 09:52 PM
Mike T's Avatar
Quoted: 316 Post(s)
Aside from weighing more, the roadster is less aerodynamic than the fortwo 450. The Cd of the roadster is 0.41 and the 450 is 0.37. However, the roadster has slightly less frontal area. That body would be working the engine really hard!
The roadster-coupe had a better aero rating, 0.39 IIRC.
You would need to design a new exhaust or at least heavily modify the regular one. You would need to find room for a fuel cooler, which on the fortwo cdi, sits under the passenger seat. The roadster is too low to have room there for that. w/o a fuel cooler, the injection system would suffer and eventually fail prematurely.
Mike T is offline
The Following User Says Thank You to Mike T For This Useful Post:
Miss Mercedes (01-13-2013)
post #12 of 16 (permalink) Old 01-13-2013, 01:15 PM
Leroy's Avatar
Quoted: 4 Post(s)
It would be no problem to put the CDI in the Roadster. If you use the Roadster fuel tank you would not have to put the fuel cooler in the car. The 2009 smart diesels have the bigger fuel tank and they did away with the fuel cooler. You would also need to change the fuel pump and modify it to fit into the gas tank. Use the 4X2 diesel wiring harness minis the Canadian add on stuff. The Roadster will work if you take out the catalytic converter inside of the muffler. Now the dash could be a different story as with the air bags and anti lock brakes. The problem is the VIN numbers on all the parts have to match to keep the check engine lights from coming on. It can be done if you use new parts and then program them to match the SAM and ECU VIN numbers.
Leroy
Leroy is offline
post #13 of 16 (permalink) Old 01-13-2013, 02:55 PM Thread Starter
cdi engine swap into 452 Roadster
Thanks Gentlemen for your valuable insights and opinions. In my experience, any engine swap can be done and is just a lot of hard work. (That plus sufficient money and dogged determination of course).
I have seen some amazing conversions come out of the least likely backyard garages. Ever been to India and witnessed what those self-taught, but extremely talented and creative folks do there with Diesel conversions? They make things happen!
robssmart is offline
post #14 of 16 (permalink) Old 07-09-2018, 09:35 AM
Did Roadster diesel come alive in America?
Roadster 800 diesel don't have to be slow, tiny engine has been beaten a long way past 100hp.
SLEI65 is offline
post #15 of 16 (permalink) Old 07-09-2018, 10:01 AM
Mod ♥ 450/451/453 + Motos
Miss Mercedes's Avatar
Quoted: 164 Post(s)
Most likely no. US border customs usually are not fond of Roadsters. I reckon the few that have leaked through were cars that overstayed their visas or brought over by members of the military and again, overstayed their visas.
Miss Mercedes is online now
post #16 of 16 (permalink) Old 05-08-2019, 08:01 AM
Quoted: 1 Post(s)
sounds like a fun swap.good luck
data883 is offline
Engine Swap possible for US-spec 451? tbone28 smart Modifications 32 05-03-2016 07:08 PM
Mercedes-Benz SLK Roadster gets a diesel engine (and returns 56.5 mpg) BigWarpGuy The Car Lounge 5 08-26-2011 07:31 AM
Engine swap M__O__S__S smart Modifications 2 05-05-2011 12:06 PM
Engine swap in 32 seconds. cubefx The Car Lounge 4 10-29-2009 11:16 PM
Hmmmmm (Harley engine swap?) jdlynch99 smart Modifications 21 08-23-2009 08:35 AM
