No start just clicks - Page 2 - Smart Car Forums
 1Likes
post #11 of 18 (permalink) Old 12-16-2015, 10:37 AM
Quoted: 52 Post(s)
If the car has autolights and automatic wipers, there is a known problem whereby the battery will drain if both are left in the on position.
~toaster
toaster is offline
post #12 of 18 (permalink) Old 12-16-2015, 05:45 PM
steveg's Avatar
Quoted: 72 Post(s)
i have seen this in a few smarts, driving the owners (and me nuts). sometimes it something stupid like a corroded connection at the battery, or ground cable on the engine to body...sam unit with a burnt connector, or realy loose...
then occasionally get the random bad battery, alternator, and even a ignition switch.... electricals are hard to track down and solve when problems come up.. my best bet is that its something stupid and ab easy fix.
steveg.
steveg is offline
post #13 of 18 (permalink) Old 12-16-2015, 08:05 PM
King of Smart Gadgetry
DreamCarOwner's Avatar
Quoted: 315 Post(s)
My battery in my smart is almost 5 years old and is starting to fail. After it sits for a couple of days the battery drains enough with the pod clock, SAM,phantom glow of my LED interior lights and my DVD <MP5 Backup camera in my rear view mirror needs power all the time, so it drasins my old weak battery. I try to start it and it just clicks the first 2 or three times I try it. If the battery is indeed low when it clicks to try to start you will hear the Pod tachometer spin up, and thats a pretty sure sign that battery voltage is dangerously low. Mine still barely starts after a few tries. The SAM will even shut off the dome light and extra things trying to conserve power to start the engine. After it starts it's good for the next day or two but I noticed about a week prior that the engine was cranking slower than usual and I noticed the dash lights and headlights dimming or pulsing a little at night. If everything stays bright during the attempt to crank, the starter solenoid is kicking in (this the click), but the starter is not spinning. You need to try and jump it to see if it starts. If you have a test meter check battery voltage with it running. It should read 13.5 to even 14.5 if it's charging hard.If it's around 12 volts running I would suspect the alternator, which I believe has a built in voltage regulator if my memory serves me right. I know car problems can be aggrevating, but you can methodically work through them and troubleshoot your problem. We can help you.
DreamCarOwner is offline
post #14 of 18 (permalink) Old 12-17-2015, 09:23 AM
OTD3 lifetime Member
jsenka's Avatar
Quoted: 115 Post(s)
Originally Posted by svaraman View Post
If you've replaced the battery that many times in that short of an interval, then clearly the battery is NOT the problem. I propose four possibilities:
1. The charging system is over-charging your battery. I'm not sure if the voltage regulator is built into the alternator in your smart or if it's a separate device but you need to check the voltage regulator.
2. There is a zombie load on your battery (light left on, electrical short, defective voltage regulator, defective electronics, etc) that is repeatedly discharging your battery. You can check this for yourself with an ammeter or have your battery shop verify that the load on the battery is very low when the car is off. You may need to check this repeatedly as the load may be intermittent.
3. The charging system is only charging the battery intermittently. This can be caused by a loose cable or intermittent alternator. This allows the battery to deeply discharge which is NOT good for lead-acid batteries that aren't designed for deep-discharge.
4. Variant of #2 : Something or somebody is leaving the lights or other electronics on when the car is off. Perhaps the timer on the headlight has gone kaput and is leaving the headlights on for 30 minutes every time you shut off the car?
Deeply discharging a lead-acid battery even once will greatly shorten its life. It's pretty easy to kill a battery in 4 months if you repeatedly discharge it.
In any case, replacing the battery is not the solution. Just because the battery is the component that is failing doesn't mean the battery is to blame. You don't blame the engine for blowing up when the oil pump fails. Similarly, don't blame the battery for failing when it is being abused by something you haven't yet discovered.
Thanks for your troubleshooting tips. As I said in my original post, these were three different cars and testing the charging system was the first thing I did! All of the failures were shorted or open cells.
chieftmc likes this.
jsenka is offline
post #15 of 18 (permalink) Old 12-17-2015, 04:47 PM
Quoted: 160 Post(s)
Shorted or open cells are caused by overcharging or deep discharging. I understand that you tested the charging system, but that does not mean that the charging system is ALWAYS working properly. From your description, it sounds like an intermittent problem with the charging system. Intermittent issues are really a pain to diagnose.
svaraman is offline
post #16 of 18 (permalink) Old 03-08-2018, 12:49 AM
smart car would not start after i sut it off for about ten minutes i went to leave and nothing car would not start it turned over but no start so i then had smart towed to house and then tried to start again turned over but no start then i checked it in the morrning and it wont even crank now all lights come on battery is good. what the hell. please tell me somthing good thanks David g
benzo12 is offline
post #17 of 18 (permalink) Old 03-08-2018, 08:57 AM
Quoted: 43 Post(s)
David, take a close look at the battery terminal on the starter. It’s prone to corrosion and can become so bad the car won’t start.
vadsoom is offline
post #18 of 18 (permalink) Old 06-29-2019, 09:58 AM
I have same issue, followed all trouble shoot Inc N11-6 no voltage. Have all guage lights including no key blinking. BATTERY @ 12.6V Car parked.
SmartNewb is offline
Remote start. lmills008 smart Operation and Maintenance 2 10-30-2015 05:50 PM
no start Brian West smart General Discussion 0 09-18-2015 03:21 PM
Inauspicious Start ScottAndersonYoga smart fortwo Electric Drive 15 06-16-2014 06:38 AM
Where Do I Start? GOT_MPG 2014 Midwest smart Rally 3 06-10-2014 09:57 AM
5 rapid fire clicks when starting car BigChief smart fortwo Electric Drive 4 04-14-2014 06:44 PM
