Inexpensive axle tube caps - Smart Car Forums
 1Likes
post #1 of 14 (permalink) Old 05-17-2011, 06:02 PM Thread Starter
Stretchmobile's Avatar
Quoted: 127 Post(s)
For some inexpensive caps look no further than your local parts store. Ask for 2 Doorman expansion plugs, part number 555-1115, $1.99 each. They measure 2.887" or 73.33mm. The axle tubes are almost exactly the same I.D. However due to the process of making the axle tube it isn't exactly roound, some deformation occurs. Which is good, because it helps hold the plugs in. I have used expansion plugs on all the open ends of off road bumpers I have built. Put them in open end first gives a nice clean finished look to them. I am having these powder coated black (only cause my best friend owns a powder coating business.) I'll post pictures when I get them in.
Name:	2011-05-13 17.57.24.jpg
Stretchmobile is offline
post #2 of 14 (permalink) Old 05-17-2011, 06:11 PM
Bohemian Moderator 451gas
Quoted: 78 Post(s)
jwight is online now
post #3 of 14 (permalink) Old 05-17-2011, 06:13 PM
Lifetime Member
Kermit's Avatar
Quoted: 6 Post(s)
Hmmm, freeze plugs. That's an idea. Pretty good. My drain covers have taken a beating over the years so it may be time for a change.
Kermit is offline
post #4 of 14 (permalink) Old 05-17-2011, 06:35 PM
Brabus007's Avatar
Quoted: 89 Post(s)
Don't forget to vent that tube, because there is two nice holes in the front of that tube to let water in...
Brabus007 is offline
post #5 of 14 (permalink) Old 05-17-2011, 07:25 PM
Seasidenj's Avatar
Quoted: 3 Post(s)
I used a 3" test plug from Home depot plumbing dept it's red with a stainless wing nut to tighten the rubber plug. Easy to remove and seals tight I like the bright red color too about $5 each
Seasidenj is offline
post #6 of 14 (permalink) Old 05-18-2011, 05:19 PM
dancote's Avatar
Quoted: 1 Post(s)
Link? Please.
Regards,
Dan
dancote is offline
post #7 of 14 (permalink) Old 05-18-2011, 06:57 PM
Quoted: 26 Post(s)
I bought some 3" red adhesive backed reflectors for $1.69 each at Clean Rite Blazer B38SR 3 3/16 Inch Red Reflector at HardwareAndTools.com. I drilled a drain hole in the bottom and stuck them on fully expecting them to fall off fairly quickly. That was 2 years and 10 months ago. They've been through 3 snowy winters, a lot of rain storms, plenty of rough roads and NJ potholes and they're still there! There's a little discoloration around the drain holes but otherwise they look as good as new.
Name:	bumper spikes.jpg
primostoy likes this.
mvaldes is offline
post #8 of 14 (permalink) Old 05-18-2011, 07:24 PM Thread Starter
Quoted: 127 Post(s)
I got them back from the powder coater. I installed them, here are some pic's. I put a bead of urethane around the inside edge and tapped them in. I'll let you know if they fall out. I doubt it. Not worried about water being trapped in the tube in southern California.
Name:	2011-05-18 18 15 25.jpg
ID:	2783   Click image for larger version
Name:	2011-05-18 18 05 06.jpg
post #9 of 14 (permalink) Old 05-19-2011, 03:04 PM
Quoted: 1 Post(s)
Nice as they look, they are going to cause the deDion tube to become a liquid-and-road-junk collection point - the tube is opened at the front, as well, so road grime, water, etc. will gradually build up inside, since you plugged the drain point, and may eventually cause the tube to rot out.
10632 is offline
The Following User Says Thank You to 10632 For This Useful Post:
kheran (05-19-2011)
post #10 of 14 (permalink) Old 05-19-2011, 03:21 PM
Smart Enuf's Avatar
Quoted: 1 Post(s)
You need to put rockets in there and make them look like rocket launch tubes. That'll keep the Hummers off your tail.
Smart Enuf is offline
DIY Axle Tube Insert tgobie50 smart Modifications 6 10-11-2010 07:18 PM
Damage to Rear Axle (DeDion Tube) rodriguez1952 smart Wheels & Tires 19 08-17-2010 07:59 PM
Red Axle Tube Covers SmartCarPerformance Vendor Deals 2 05-31-2010 10:34 PM
Rear Axle Tube End Caps BreathlessPerformance Interior & Exterior Styling 0 03-23-2010 10:39 AM
Recommend accessory...axle tube covers... willow1308 smart Modifications 18 02-22-2010 12:23 PM
