smart LED - Build log - Smart Car Forums
post #1 of 11 (permalink) Old 09-21-2013, 07:01 PM Thread Starter
Jarleif's Avatar
Quoted: 2 Post(s)
Task#1 - Cargo Light
I have 4 of these -
120 degree - 3W - Cool White
should light up the cargo area pretty well..eh?
Anyone have any ideas as to how to mount these behind the plastic cover at the very rear of the roof of a coupe? I'm obviously drilling holes, but I haven't found any recessed mounts for the CREE stars...I wonder if superglue would do the job?
I've superglued regular LED's into drilled holes in the past..my previous car had several thousand LEDs..in various locations..
but I've never flush mounted CREE LEDs..until now.. ;)
Seeing as LEDs are really cheap, and I really enjoy lighting things up, The smart will likely be lit up as well..tastefully of course..
Stay tuned for pictures!
Jarleif is offline
post #2 of 11 (permalink) Old 09-21-2013, 07:13 PM
Stretchmobile's Avatar
Quoted: 127 Post(s)
Bet you love Christmas!
Stretchmobile is offline
post #3 of 11 (permalink) Old 09-21-2013, 07:31 PM Thread Starter
Jarleif's Avatar
Quoted: 2 Post(s)
Absolutely!
Jarleif is offline
post #4 of 11 (permalink) Old 09-22-2013, 04:15 AM
Bohemian Moderator 451gas
Quoted: 78 Post(s)
jwight is offline
post #5 of 11 (permalink) Old 09-22-2013, 07:20 AM Thread Starter
Jarleif's Avatar
Quoted: 2 Post(s)
That's what I'm doing..although I'm most likely tapping into the SAM for "rear hatch open", and I'm also using a 1ohm 5w resistor in series with the LEDs - don't wanna blow 'em, say during a jump or an alternator/VRM malfunction..
The supply voltage is not always 12v either, since I plan on the occasional opening of the hatch with the car running...with the car running it should be around 13.8-14.6v
So with a worst case scenario of 14.6v, each LED runs at 3.65v - more than the designed forward voltage of 3.6v, ie. the current will start creeping above 750mA pretty quick..which will more than likely result in at least one LED going poof!
Great writeup though - Thanks!
Jarleif is offline
post #6 of 11 (permalink) Old 09-22-2013, 07:22 AM Thread Starter
Jarleif's Avatar
Quoted: 2 Post(s)
yes, I know 5w is overkill - no point in skimping on this one..we're talking pennies here.. ;)
Jarleif is offline
post #7 of 11 (permalink) Old 09-22-2013, 07:31 AM
Quoted: 209 Post(s)
Here's a nifty calculator for LED circuits......
LED Calculator - Current limiting resistor calculator for LED arrays
kheran is offline
post #8 of 11 (permalink) Old 09-22-2013, 05:30 PM Thread Starter
Jarleif's Avatar
Quoted: 2 Post(s)
Just finished building a current regulated circuit with a LM317T, set to 625mA with two 1Ohm 5W resistors in series. It's operating 125mA below the normal operating current of the LEDs, so I'm under powering the LEDs..consistently, regardless of voltage variations of the supply voltage! Mission accomplished!
It's running cool, and the heatsink is way oversized, but insted of spending money on one, I grabbed an old Pentium 60 heatsink out of the stash, and just drilled a hole in it! Yes i used silicone paste...Works like a charm!
Good God these things are bright!! :eek:
Now for mounting into the plastic panel!
Jarleif is offline
post #9 of 11 (permalink) Old 09-23-2013, 08:58 PM Thread Starter
Jarleif's Avatar
Quoted: 2 Post(s)
Some more pics from last night
ID:	5753   Click image for larger version
ID:	5761   Click image for larger version
Jarleif is offline
post #10 of 11 (permalink) Old 09-23-2013, 09:02 PM Thread Starter
Jarleif's Avatar
Quoted: 2 Post(s)
I ended up wiring this in to the dome light switch, by drilling out two of the plastic "rivets" holding the metal on, and using a really small fine thread screw, the exact diameter of the hole in the metal. I used some old molex connectors, like the ones you see in a computer, for quick disconnects. I'm happy with it, and it's bright to boot! (see what i did there?!)
Jarleif is offline
HOW TO: Taillight wiring for trailers/LED's & add-on LED light strip stop/turn lights Kermit smart Operation and Maintenance 12 11-03-2012 04:49 PM
LOG-IN and let us know you are here SMART New Members Area 28 02-15-2008 09:49 PM
Accident Log rwj53 smart Operation and Maintenance 0 02-05-2008 04:26 AM
