2013 ForTwo Radio Harness Wiring - Page 2 - Smart Car Forums
post #11 of 11 (permalink) Old 03-26-2014, 06:17 PM
Woody14619's Avatar
Quoted: 75 Post(s)
Originally Posted by goney3 View Post
I've looked at the 2011/2012, opened my unit, and their are different colors.
The connectors are pretty simple. The connector cable from SmartMadness has what the line is used printed directly on the wire itself ("+12V constant", "+12V switched", etc). The connector that comes with your head unit should have the same, or should have a pin-out indicator with it specify function per line. You want to match function to function, not color to color.
Wire color is highly irrelevant. Different manufacturers use different colors. Smart has even changed the colors of the wires going into the connector on the car side a couple times over the years (usually mildly, brown to grey, etc). What matters in where the pins are. The pin-out for 2013 is the same as 2011/2012, that's all that matters.
As for the 2011 pin-out diagram, I don't have it handy. I grabbed it off of Evilution, printed it, and put it in the box with the spare head years ago. I have no clue where that sheet/box is right now.
What I recall was the only real change 2008 to 2011 change was that the "+12V switched" line moved to a previously NC slot (A6?). The only 2013 change appeared to be they separated sub/amp lines to separate pins (A4 to A4/A2?).
Now please try to be more helpful and less curt.
With attitude like that? You're lucky people are being helpful at all.
Woody14619 is offline
harness , radio , wiring
2012 ForTwo Radio Harness Wiring Yappyfox Audio & Video 27 10-28-2018 04:08 PM
Help, need a 2011 pure radio wiring harness diagram cheapbutsmart Audio & Video 16 11-30-2016 06:10 AM
SRS Light = New Wiring Harness lharmon20 Indiana Chapter 14 10-01-2011 10:26 AM
stereo wiring harness? bentoutofshape Audio & Video 5 06-29-2010 03:11 PM
wiring harness update SmartTech Audio & Video 2 06-27-2008 06:47 PM
