Tweeters in the A pillars. No disassembly required. - Smart Car Forums
 1Likes
  • 1 Post By Derekns74
post #1 of 6 (permalink) Old 06-15-2013, 04:20 AM Thread Starter
Derekns74's Avatar
Quoted: 70 Post(s)
While trying to figure out how to get the A pillar trim off to install tweeters, it occurred to me that I didn't need to. I mounted them fairly low, but the wire fed very easily behind the panel.
I used a cardboard template to get the holes in the same place. I pressed a grommet onto the cardboard to make it easier to mark the surface through it. After that, it was very easy to feed the wire through. If you planned to mount them higher, you would probably need a fish tape.
Derekns74 is offline
The Following 2 Users Say Thank You to Derekns74 For This Useful Post:
Brabus007 (06-15-2013), RickyM (06-15-2013)
post #2 of 6 (permalink) Old 06-15-2013, 04:23 AM Thread Starter
Derekns74's Avatar
Quoted: 70 Post(s)
Alpine 1 cm hard dome tweeters, btw. I really don't care for Rockford Fosgate tweeters.
The Following User Says Thank You to Derekns74 For This Useful Post:
RickyM (06-15-2013)
post #3 of 6 (permalink) Old 06-15-2013, 08:47 AM
RickyM's Avatar
Quoted: 16 Post(s)
did you use screws or 2 sided tape to hold them to the panel. Very cool and easy way to do it.
RickyM is offline
post #4 of 6 (permalink) Old 06-15-2013, 01:50 PM
Bohemian Moderator 451gas
Quoted: 78 Post(s)
Aren't there factory wires under the black triangle behind the rear view mirrors?
jwight is online now
post #5 of 6 (permalink) Old 06-15-2013, 03:52 PM Thread Starter
Derekns74's Avatar
Quoted: 70 Post(s)
I used screws to hold them. The reason I didn't put them in the doors is that I amplify my highs mids and lows seperately. My HU is a Pioneer DEH80-PRS. It has an internal crossover network, and outputs HML, not FRS. I can change all of the crossover points and slopes on the HU.
The factory wiring is set up for the tweeters and the mids to be wired to the same channel. I would have had to run new wires into the doors anyway.
My 4-channel amp is in the giant space above the passenger's feet, and my mids are fed through the factory door wires. I don't use the internal amp in my HU (disabled), so I just ran the outputs from the 4 channel amp back to the wiring harness, and connected them where you would normally connect the front channel outputs from the HU.
Highs and mids are getting 75w RMS per speaker on a 300x4 amp at 4 ohm, and my 2 dual voice coil 12" P2D2 Fosgate subs are getting 300w RMS (combined) on a 500x1 amp running at 2 ohm.
The doors have Fosgate PPS4-6 6.5" mids, and the tweeters are Alpine SPS-1005's. At a later date, I plan to add 2 PPS4-8 8" mids to a ported wedge on the top of the sub box. I'd drive them with a 300x2 amp running 4 ohm for 100w RMS.
It all sounds expensive, but I had almost everything from my 2010 Corolla. I had to return it to stock to trade it in on my cabrio.
Smartbtd likes this.
jwight (06-16-2013), RickyM (06-15-2013)
post #6 of 6 (permalink) Old 06-15-2013, 05:46 PM
mer071898's Avatar
Good job! There's better soundstage with the tweeters up higher, which is my preference also.
mer071898 is offline
Brabus Suspension - EPS Required !? Just George smart General Discussion 24 09-18-2012 02:24 PM
How Much Boost Before Required Tune? smartcar111 Turbo 20 06-07-2011 01:45 PM
Urgent help required (3 bars) EbenE Modifications and Repairs 12 04-05-2010 12:10 PM
A/C Climate Control Disassembly phamnw Interior & Exterior 4 07-24-2009 01:35 PM
Mirror Disassembly getsmartusa Interior & Exterior 1 09-04-2008 07:29 PM
