Blue Ox Tow Bar Impressions - Page 4 - Smart Car Forums
post #31 of 37 (permalink) Old 04-05-2012, 07:51 PM
Bungee Fix
Thanks both of you. Your fix makes more sense than my door to door one. Funny that I did not read about this more often in this forum. Thanks again.
SWNimz is offline
The Following User Says Thank You to SWNimz For This Useful Post:
Kermit (04-05-2012)
post #32 of 37 (permalink) Old 06-12-2012, 06:30 PM
Thanks. Similar to what I do but I don't like the way the tires scoot around tight corners. I tried adding 40 lb of weight to the front today and pulled without the bungee. Worked fine for a little over 100 miles. Then after pulling over to check a map and back on the road, the front end did the usual side to side thing. Put the bungee on and everything was ok.
I would really like to find a method where the front tires don't scoot around corners.
Des
donschweika is offline
post #33 of 37 (permalink) Old 06-18-2012, 10:27 AM
I am in the process, last Saturday, of purchasing a 2009 Smart to tow behind my 36 ft Motorhome, I presently have a Blue OX that is used to tow a Jeep. I got a call from the Dealer this morning that he was talking to the Shop Foreman when he got in about a battery disconnect and the foreman said that Smart no longer recommends a Smart be towed 4 down. Has anyone had any problems with towing 4 down without a battery disconnect or having the car lock up because of the security system that will lock the car if the key is off and the car moves over 8 mph, or even transmission problems, this is what the shop foreman says why Smart does not recommend towing 4 down anymore.
JEB2009smart is offline
post #34 of 37 (permalink) Old 06-18-2012, 11:57 AM
ManchVegas's Avatar
Quoted: 26 Post(s)
JEB, I replied here:
https://www.smartcarofamerica.com/for...72/#post517854
There is no need for double posting in SCoA.
ManchVegas is offline
post #35 of 37 (permalink) Old 07-03-2012, 01:09 PM
I have towed my 2008 Smart from FLA to CALIF and back and from Fla to NY and back with no trouble. I secure the steering wheel with bungee chord to stop tire wobble and disconnect the battery. When I hook up battery, it takes about 2 minmutes before all systems come alive.
JJJOHN is offline
post #36 of 37 (permalink) Old 11-16-2017, 07:57 PM
Question I asked the person at the smartcar center of Abq if disconnecting the battery was needed he said no just bungee the steering wheel leave it in neutral and have the tow bar setup. Who leaves the battery connected?who disconnects it?
BlackeyCole is offline
post #37 of 37 (permalink) Old 11-16-2017, 09:17 PM
ManchVegas's Avatar
Quoted: 26 Post(s)
I had a battery disconnect switch installed. Why? Because the owners manual says to disconnect the battery when towing. Read the caveats of not disconnecting the battery that is found at the end of the towing section in the owners manual.
First impressions bull8042 smart General Discussion 17 05-12-2008 04:22 AM
smart first impressions jwkriz New Members Area 2 05-04-2008 05:48 PM
First day impressions dennyrex smart Delivery 5 05-02-2008 12:03 PM
First Impressions on New Delivery kmeinhold smart Delivery 16 01-26-2008 12:43 PM
First Impressions... bmx43 smart General Discussion 13 01-19-2008 11:29 AM
