P2177 System Too Lean Off Idle Bank 1 - Smart Car Forums
 2Likes
post #1 of 40 (permalink) Old 03-22-2011, 10:59 PM Thread Starter
shadowchameleon's Avatar
Quoted: 2 Post(s)
ok so i know we covered this when i went to Lincoln Tech, but i think it was on the day i got a new phone to play with during class. I was sitting at a red light and it turned green, i began to accelerate and my engine light popped on. I went to Advance Auto Parts and used their scanner. It said two codes of something like: system too lean off idle. I dont remember the code exactly but erased it. Then about a week later it does it again same conditions i am going back to AAP to scan it and will write down the codes. Based on that what do you guys think? oh and i am right at 30k miles.
Last edited by rfernatt; 03-24-2011 at 05:59 AM. Reason: Change title per OP's request...
shadowchameleon is offline
post #2 of 40 (permalink) Old 03-23-2011, 05:00 AM
WhiteNBlack08's Avatar
Quoted: 360 Post(s)
Sounds like your not getting enough fuel enrichment off idle. This could be caused by a few things, most of which can get expensive. Just curious, since you are at 30K, have you changed your plugs yet? Although I would think poor spark would lead to a rich setting not lean. Try running a bottle of injector cleaner through your next tank.
After that, it gets expensive, possible low fuel pressure, possible bad injector, ect. Having the exact code will help.
Hope it's an easy fix.
WhiteNBlack08 is offline
post #3 of 40 (permalink) Old 03-23-2011, 05:33 AM
Quoted: 84 Post(s)
When is the last time you changed/cleaned your air filter ??
chieftmc is offline
post #4 of 40 (permalink) Old 03-23-2011, 08:26 AM
Quoted: 787 Post(s)
Had that happen on my Expedition a fewtimes. Once it was a melted vacuum line the next time it was from the kid adding oil and he didn't put the oil cap back on. Found the cap on the battery.
jimvw57 is offline
post #5 of 40 (permalink) Old 03-23-2011, 08:45 AM
Normally the smart tends to run a bit on the rich side of things from what I have seen.
smarticus is offline
post #6 of 40 (permalink) Old 03-23-2011, 10:45 AM Thread Starter
Quoted: 2 Post(s)
lean is too much air or too little fuel, right? For some reason I did clean and recharge my drop in K&N, but wouldn't a dirty air filter mean less air, therefore rich condition? And if the filter were to restrict the air, a sensor would pick it up and compensate before getting to the engine. I have not changed my plugs yet but plan to. If the plug didn't ignite the contents of a cylinder, wouldn't that let excess O2 pass to the exhaust, therefore creating a lean reading. If its the injectors...
post #7 of 40 (permalink) Old 03-23-2011, 11:16 AM
Quoted: 787 Post(s)
Lean would be too much air, not enough fuel. A leaking or disconnected vacuum line, or oil cap missing will allow air to get in after the map sensor and lean out the mixture. Could be a leak in the exhaust system too.
I'd look for a disconnected hose first.
jimvw57 is offline
post #8 of 40 (permalink) Old 03-23-2011, 12:50 PM Thread Starter
Quoted: 2 Post(s)
post #9 of 40 (permalink) Old 03-23-2011, 02:09 PM
Quoted: 84 Post(s)
I think I read on another thread (can't find it now ) someone else had this problem and ended up having to replace the gas pedal assembly
chieftmc is offline
post #10 of 40 (permalink) Old 03-23-2011, 02:11 PM
Gas pedal assembly?!? That should have nothing to do with the mixture...
deepblueQ is offline
« replacing roof | - »
Lean the seat back? Youmaylose smart General Discussion 21 04-07-2010 09:12 PM
Going lean on the smart? VinceLA smart Modifications 16 07-24-2008 02:18 PM
just got orphan, from behind it looks like rear wheels lean inward mnext02 smart General Discussion 5 05-04-2008 07:05 PM
