P2177 System Too Lean Off Idle Bank 1 - Page 2 - Smart Car Forums
 2Likes
post #11 of 40 (permalink) Old 03-23-2011, 02:54 PM
Smartfor2guy's Avatar
Originally Posted by deepblueQ View Post
Gas pedal assembly?!? That should have nothing to do with the mixture...
On a drive by wire? Maybe
Smartfor2guy is offline
post #12 of 40 (permalink) Old 03-23-2011, 06:28 PM
Brabus007's Avatar
Quoted: 90 Post(s)
Brabus007 is offline
post #13 of 40 (permalink) Old 03-23-2011, 06:39 PM
Quoted: 2 Post(s)
Definitely not a fan of K & N. I know their website dispells "MAF myths" and do testing on behalf of consumer complaints from MAF failure issues. I had one evaluated by them, and guess what, no problem with the MAF. Just like a defense attorney giving his client a lie detector. Too many details to go into including how they use the Magnuson-Moss Warranty Act.
That said, it could either be your MAF or an oxygen sensor bank 1. Either way, try not to drive the smart too much. It could potentially overheat the catlyitic converter.
pack smart is offline
post #14 of 40 (permalink) Old 03-23-2011, 06:58 PM
BARNEY O's Avatar
Quoted: 123 Post(s)
Smart car does not have a "maf" sensor but does have a "map" sensor.
BARNEY O is offline
post #15 of 40 (permalink) Old 03-23-2011, 07:13 PM
To the XCAPEPOD!
rfernatt's Avatar
Quoted: 68 Post(s)
Since the MAP sensor readings are combined with air temperature to compute air mass, could a malfunctioning temperature sensor (I presume the same one that gives temp readings on the dash) cause a lean/rich issue? Of course, I'm way out of my league on this one...
rfernatt is offline
post #16 of 40 (permalink) Old 03-23-2011, 07:26 PM
Quoted: 213 Post(s)
..yes..a bad T2 sensor will affect fuel management...but since most T2's are fixed resistors they don't come and go...they usually just go...
jetfuel...good call RF..
jetfuel is offline
post #17 of 40 (permalink) Old 03-23-2011, 07:33 PM
BARNEY O's Avatar
Quoted: 123 Post(s)
Shadow, went back to your original statements and trying to put everything in sequence. You mentioned seeing 2 codes?
Did you clean and reoil your K&N filter, then you had this issue ?
BARNEY O is offline
post #18 of 40 (permalink) Old 03-23-2011, 07:55 PM
On a drive by wire there are just two signals: main and backup. These are just voltages. Backup is half voltage of main, and only used to determine if something is wrong with the main signal. If something goes wrong with the accel assembly, it would cause errant load at the ECU. The load can be anything you want, but it won't affect the mixture. At anything below ~5200RPM, the only load with non- 14.5:1 AFR is 0 (fuel-cutoff coasting).
Maybe if there was a loose connection or something and the accelerator signal kept jumping between 0 and <desired load>, you might get a lean mixture CEL... but I doubt it, and I really doubt that you wouldn't get much more pressing issues than the AFR...
deepblueQ is offline
post #19 of 40 (permalink) Old 03-23-2011, 08:20 PM Thread Starter
shadowchameleon's Avatar
Quoted: 2 Post(s)
i got my K&N filter just before Nationals sometime in April or May. Engine light, 2 P2177s, erased, recharged my filter, week later engine light, 2 P2177s, erased as of 4 or 5pm today. And im at 30k mi. Enginewise i have only replaced oil, oil filter, and air filter.
shadowchameleon is offline
post #20 of 40 (permalink) Old 03-23-2011, 09:44 PM
Quoted: 2 Post(s)
shadowchameleon:
I wish your original post Title could be changed. I don't think that can happen within the OP scope of this particular forum, however I could be wrong.
New Title to the original post suggestion. "P2177 System Too Lean Off Idle Bank 1".
It will help out the smartie family as we find codes and research.
« replacing roof | - »
Lean the seat back? Youmaylose smart General Discussion 21 04-07-2010 09:12 PM
Going lean on the smart? VinceLA smart Modifications 16 07-24-2008 02:18 PM
just got orphan, from behind it looks like rear wheels lean inward mnext02 smart General Discussion 5 05-04-2008 07:05 PM
