Cabin air filter questions and comments - Page 2 - Smart Car Forums
 14Likes
post #11 of 20 (permalink) Old 04-28-2015, 12:21 AM Thread Starter
coupe1942's Avatar
Quoted: 72 Post(s)
Picked up the spare Fram filter today, but immediately noticed that is is about half the thickness of the cabin air filter I took out of my Smartie. The one removed was printed on the side, but the writing is difficult to see clearly. Looks like Mann filter, CUK 2132. (like say, it is difficult to read the lettering now).
I'll still attach a tape tab for easier removal, but will also check out the filter I have at Advance to see what it looks like before deciding which to use first.
After this, all my routine maintenance is done for a bit, so I can then relax and just think about how to use my 36 minutes of wasted time left this year from worrying over my key taking so long to work on the car when I turn it on.
coupe1942 is offline
post #12 of 20 (permalink) Old 04-28-2015, 01:40 AM
aka 'smart-1'
ca smartone's Avatar
Quoted: 85 Post(s)
ca smartone is offline
post #13 of 20 (permalink) Old 05-02-2015, 11:01 AM
Bohemian Moderator 451gas
Quoted: 78 Post(s)
Here's a pretty good video:
It's not as simple opening the housing door as I portrayed it; the two tabs have to be squeezed in before the door pops open. And your idea of adding a tab to the filter is an easy way of avoiding having to fish the filter out with a screwdriver or similar tool.
jwight is offline
Sensei Grant (05-02-2015)
post #14 of 20 (permalink) Old 05-02-2015, 11:20 AM
He's not mine
NCC1701's Avatar
Quoted: 380 Post(s)
For what it's worth, I had a heck of a time replacing mine as well. Not the actual replacement, but wiggling myself into position, opening and re-securing that little door gave me a headache. In my case, I learned that a properly positioned light source would've been a great help ... not being able to see what I was doing made it a lot harder. Properly lighted, I think my next one will be a lot easier. I'm no spring chicken either. And my eyesight ain't what it used to be.
jwight and chieftmc like this.
NCC1701 is offline
post #15 of 20 (permalink) Old 05-02-2015, 01:28 PM Thread Starter
coupe1942's Avatar
Quoted: 72 Post(s)
I can relate, as my door still sits on the passenger seat at present. It awaits my body to once again contort to attempt to reinstall it. I need to pick up one of those headlight bands with the led light on them so I can see, as you mention. The original problem was that the cabin air filter I was trying to remove was about twice the thickness of the replacement one I installed. I put a tab on it and that should make it all the easier to remove and replace the next time around, for sure. Try as I may, my arms do not stretch out well enough to make putting that darn door back into place. My knees don't tke kindly to the driveway cement, either. I need to finish this task and be done with it though. Maybe a few jumping jacks and some knee bend stretchess may be in order before I attempt it though. That and increasing my life insurance policy.
post #16 of 20 (permalink) Old 05-02-2015, 02:21 PM
10Year+ Supporting Member
1983JZR3W's Avatar
Quoted: 284 Post(s)
I am old and have bad knees and a bad back. Just your typical old age maladies. Whenever I need to do kneeling work on my smart (installing the GoPedal for example), I borrow my dog's 4 inch thick foam bed and kneel on that in the garage. I also have small clip on lights that really brighten up the work area. They easily clip on to most any part under the dash and have worked for me really well for a while now.
jwight, NCC1701 and Smart Bob like this.
1983JZR3W is offline
post #17 of 20 (permalink) Old 05-02-2015, 02:40 PM
Smart Bob's Avatar
Quoted: 175 Post(s)
When I am changing my cabin filter or doing some under dash work, I simply drive the vehicle up on a set of ramps, which makes access easier to the under dash area. Using an LED headlight or visor light is also a good idea.
NCC1701 likes this.
Smart Bob is offline
The Following User Says Thank You to Smart Bob For This Useful Post:
Sensei Grant (05-03-2015)
post #18 of 20 (permalink) Old 05-02-2015, 04:06 PM Thread Starter
coupe1942's Avatar
Quoted: 72 Post(s)
Thanks for the tips. My neighbors are starting up a petition to make me stop showing my "plumber's butt" as I bend over to work on my Smartie the next time. They forget that I am old and my First Alert button won't respond to me yelling, "Help, I've fallen and I cant get up.....and by the way, how do you put this damn plastic door back in the cabin air filter slot of my Smart Car?"
post #19 of 20 (permalink) Old 05-02-2015, 06:50 PM
aka 'smart-1'
Quoted: 85 Post(s)
If I lived closer, I'd offer to come over and button it back up..
Just did mine for the fourth time, took all of two minutes, start to finish.
No Spring Chicken here either
This is the little light I use, it lives in the car .....
Stanley 95 111 Maxlife Mini Tripod Flashlight New | eBay
NCC1701 likes this.
post #20 of 20 (permalink) Old 05-03-2015, 07:42 AM Thread Starter
coupe1942's Avatar
Quoted: 72 Post(s)
I got my Smartie backed up onto my metal ramps to do that trailer hitch thing today, but din't try to put the door back onto the cabing air filter just yet. I have on a pair of knee pads and that sure makes it much easier on my knees. Ran out of steam, as I didn't sleep last night, so I'll take a quick cat nap and try to do more on both projects later today. Those bolts are locked into place pretty well, so I have to find my breaker bar and see if I can get some oomph in removing them all. I have a good light to see with, but it had not been charged up and I had misplaced he charger for it. Got my serpentine belt protector off and basically ready to start removing bolts for the hitch installation. Got to watch the video one more time before I get ahead of myself.
I sure wish we were not on water restrictions here, as the bottom area of the car is sure dusty and dirty. I'd really love to hit it with a hose to remove a lot of the crap there. Can't do it though, as the water restrictions are tough down here.
The end of the album has the most recent photos of the car having the hitch put on. Hope this loads okay.
https://www.flickr.com/photos/a1930f...7651433560220/
What is it? (cabin air filter?) hoot8mon smart Operation and Maintenance 7 04-15-2013 07:47 PM
Cabin air filter CorkyF smart Operation and Maintenance 9 02-05-2012 04:38 PM
Cabin Air filter at autozone coreyeh smart Operation and Maintenance 19 08-21-2011 05:40 PM
Cabin Air Filter (DIY) CRC2362 smart Operation and Maintenance 6 06-29-2009 08:23 AM
Cabin Air filter installation gasmizer New Members Area 2 02-18-2009 01:18 PM
